[CFW Nokia X6] - Photon C6-03 Final
manhnguyenvn
Thấy dạo này không có ai post CFW cho X6 cả, mình post bản đang dùng cho ai thích.
Bản này Cook lại dựa trên bản Nokia X6 - Photon C6-03 - The Fastest Firmware - Final Released!
http://forum.smartphonegeeks.in/index.php?topic=7.0
Vài hình ảnh
[PASS][HIDE]=====================
Performance Upgrades:
- Highly Increased Application/Gaming frame rates
- Increased Response Rate (Now touchscreen will be more responsive)
- CPU frames render was increased.This will result in a smooth phone experience.
- Graphical Complexity reduced. Performance Booster without any side effects.
- Music Player response highly increased (Instantly pauses/plays on clicking the buttons)
- Reduced effects complexity which should result in a speed increase
- Increased Heap Size further to boost up performance
- Lags in Menu, messaging and Other Large Applications removed
- Polished the UI for heavy usage
- Phone will never slow down and the RAM won't be decreasing (RAM Caching modded)
- 80MB+ on C:\ (Phone memory)
- Free RAM after startup : 64.5MB in 5800, 70.8 MB in 5233 (Maximum)
- Average RAM: 60-65 MB free
- Smooth Kinetic Scrolling
- Music Player is now a lot more faster!
- Real Hack! (No need to use installserver.rmp patch anymore)
- CPU mod optimized to get complete stability and a great battery life!
General Modifications :
- "Restart" Option instead of "Lock Screen and Keys" in Power Menu by CODeRUS.
- Full N8 IconPack is used. (With 0 bugs) Now icons change according to the theme applied.
- N8 Swipe to Unlock theme and N8 dialer added.
- PC/OVI Suite will recognise your phone as Nokia C6-00. However every website including OVI Store will recognise your phone as Nokia N97 mini
- All C6 lights problem fixed. (Mod by mara)
- Camera will not eat RAM after closing it.
- Default Browser user agent changed to the one of N97 mini. So OVI store and some other sites will recognise your phone as Nokia N97 mini
- C5-03 Keyboard Layout added.
- Female Voice (Ellen) added in Message Reader app.
- Camera Sound will be disabled if you use Capture Tone 3.
- "Nokia Tune" from N8 added.
- Display lights timeout and automatic keyguard time set to 30 seconds.
- Default bluetooth name: Nokia Photon C6-03
- FOTA reserved space romoved to get more space in C:\ (Phone Memory)
- USB now will name as Nokia Photon
- Voice recording during call fixed. Your phone won't crash if you record and call someone at the same time.
- RAM Cache in C:\ for better performance
- Blazing Fast Screen Rotation
- CPU load decreased (Get a very fast phone)
- Enabled lock/unlock vibration
- Disabled My Nokia Service
- Zero start up of background applications
- Auto optimization of RAM cache for keeping up your phone faster even after heavy usage
- Default Web Browser bookmarks are edited.
- Blank UDA supplied to get highest possible free space on C:\
- Lags in Menu removed. The Kinetic Scrolling is optimized (It is no very fast not very slow)
- Display rotation is ON by default
- Breathing light is OFF by default
- Digital clock set as default. N8 Clock fonts used so the digital clock now looks like the N8 clock
- Display light turns OFF and Phone gets locked in 30 seconds
- Default Fonts Used
- Operator Logo ON/OFF settings available in homescreen settings
- Delivery Reports ON by default in Messaging
- Theme effects are OFF by default
- Removed "Check for Updates" in Device Updates
- "Summary after call" and "speed dialing" ON by default
- "In call timer" ON by default
- Profile "General" renamed to "Photon"
- Homescreen landscape enabled. Dialer landscape disabled
- Lags in Messaging apps removed[/HIDE]
[/PASS]
Một số chỉnh sửa
- Thêm tiếng Việt (mặc định)
- Thêm âm lịch
- Thêm music timer vào trình nghe nhạc
- Bản đồ Ovi Map 3.06
- Hiệu ứng bong bóng
- Tap to unLock
- Mod 4G
- Âm thanh, hình ảnh khi khởi động E:/Boot/Startup.mp3 Startup.gif
- Thư mục bảo mật E:/MNG
Cảm nhận chủ quan
- Ram khi ổn định, mở hiệu ứng... 42MB
- Nhanh, nhẹ nhàng
- Chưa phát hiện ra bug nào cả
Link download
Binh24 C6 Ported Core Files
Rofs2
Hiệu ứng bong bóng down từ Pdaviet mà, đâu có xa lạ đâu. Làm biếng chụp hình điện thoại quá.
Nhìn kái hình đẹp vãi hàng.Tính flash thử xem sao,mà thấy chữ canh gjữa nên thôi.k thấy kái đấy.mà củng k pít mod bỏ canh gjữa nên ung dung xài tiếp bản cũ.kaka.
Mà chủ thớt ác thjệt.chả chịu nhờ google dịch phát.để a e đọc mún lồi con mắt mà mí hjểu 80%.còn lại k có từ đjển.potay.hjchjc
Ko ngờ cái bong bóng của mình làm ra mà nhiều bác sử dụng nó để làm effects gốc đến thế hức hức :((:((:((:((, xúc động quá :((:((:((
Mà bản này đã thêm cái mod thêm 5MB ram của bác Kiên chưa bạn? Nếu mà thêm rồi thì ram hơi ít, còn chưa thêm thì chắc ram cũng bằng cái FW N97 mình đang dùng, 47MB bọ :D
Cái của bác Kienvp chỉ dành cho fw gốc thôi.mình cài r chả thấy khác biệt.66mb vẫn là 66mb.
lâu quá đây bác ơi.up nhanh cho anh em còn flash nữa.bắt anh em thức đêm thế này có lỗi lắm đấy
Chắc bạn ném mấy cái mod txt ấy vào rofs2 rồi mới ko có sự thay đổi chứ mình thấy thay đổi rõ rệt luôn, ko chỉ cho FW gốc đâu. Từ hôm cài mod đó RAM chưa bao giờ dưới 45MB khi ko có trình chạy ẩn mà.
sao mà bác giới thiệu mãi mà khôg có LINK cho rồi thế.....up mau cho ae đi bác ơi...gắng thức đêm nay up đi để mai ae còn flash nhé..hi..thank bác
Sorry vì chậm trễ, upload chậm quá à.
Bác nào thích flash thì vài bữa mình up cho. Tại hay lang thang bên dailymobile và pnht down các bản CFW mới ==> việt hóa . Nên cũng có nhiều bản lắm :-?
up CFW của n97 lên luôn đi bạn, nhân lúc x6 đang đc quan tâm nhiều, để a e có thêm chọn lựa.
Bản CFW N97 cho X6 cũng giống với các bản C6 cho X6, Ram nhiều hơn xíu. Nhưng mà Dialer lại giống của X6, nên không thích
Mạng mình trả sau ko up được, chết tiền net mât :|. Lấy tạm nguyên bản của bác binh24 vậy. Chắc do là bản beta nên bác binh24 ko giới thiệu trực tiếp trên PDAViet (hoặc cũng có thể bác ý quên :P):
Core for X6 V31.0.004
RM-559_31.0.004_N97 Mini ROFS2
Sau 3 ngày sử dụng thì mình thấy:
+ Khá hoàn hảo cho dù nó là bản beta, ram ko cao nhưng cũng chấp nhận được.
+ Cái xoay màn hình hơi tệ, nhiều lúc để ngang điện thoại ra nó cũng vẫn nằm dọc. Mình tưởng máy bị hỏng cảm biến nên flash lại bản X6 gốc thì cảm biến rẩt ngọt -> do FW N97.
+ Thêm nữa là ko có bàn phím tự search danh bạ (mình cook vào thì bị lỗi).
+ Bấm và giữ nút Del ở bàn phím qwerty full màn hình thì nó ko xóa liền một mạch, đành phải bấm liên tiếp vậy.
Các bác nào thích mod lại thì lưu ý bản N97 rất khó mod, ko giống bản C6 đâu. Tốt nhất là chỉ mod các file 10202be9 thôi, còn các mod như đổi bàn phím Qwerty khi xoay màn hình, quản lý file đọc được file hệ thống, ... mod vào là bị lỗi ngay.
Cái mình thích nhất ở CFW N97 đơn giản là có cái effects trong menu thôi, thử cài cái N-gage nhưng ko được :D
