FIRMWARE C6 V20.0.042 NOW WOKING ON X6 V30.0.003
Credits to CONII,PNHT
Thanks to all people are working on this !
How to use this CFW:
1. Download the appropriate version for you phone basing on the correct model and variant (RM-xx)
2. If you plan to add your language, download the language pack from HERE and follow the steps
3. Copy the provided FW directory to you Products folder (See tutorial) and flash using JAF. Warning: ROFS3 file mustn't be in the FW directory. If this file exists, delete it!
Detele system folder from memmory to best effect
(private/sys/system/resource)
or do a format
DO NOT USE ROFS3 FILE
Features/News
- Widgets HomeScreen with access to latest widgets from Nokia/Ovi
- New browser/PhotoViewer
- New email app
- Full like C6 original with QuickOffice and Adobe Reader removed
- TTS fully working
- Ovi Store and Ovi Sync Fully working
- Maps 3.04 Original
- New Fully Working Language Packs (Arabic, Farsi, Thai ...)
- Prehacked using patched installserver
- New dialer from sym v3
or do a format
Warning from PNHT ! Read Carefully
- Don't Swap ROFS2 files between different phone variants. This will kill your phone!
- Don't flash using a higher version if you plan to revert back to an older version!
- Favorite contacts:Copy your old contacts to SIM, then Soft reset your phone. After that, copy from SIM to phone. It should work fine
- Before nagging about a bug, use the Search function and see if there is a solution. If not, post your bug in the forum.
- There is no way to remove themes that are in CORE. Don't waste your time asking about that.
[video=youtube;NbyJk06ayv4]http://www.youtube.com/watch?v=NbyJk06ayv4&feature=player_embedded[/video]
