ngoanrazor
Well-Known Member
Post Updated: 07/03/2010 22:00
The application now detects which ROFS images are editable and flashable.
It identifies protected ROFS images!
Greetings Modders and Chiefs!
After so much hard work, PNHT proudly present their Second Modding tool!
Today i'm releasing my first beta of my GUI tool to cook ROFS images for your beloved phones
First a big thanks to Szakalit, Steven25, Downin, Popizo all beta testers who helped validate this release
Disclaimer:
This tool is for educational purpose only! Flashing modified firmware is strictly prohibited by Nokia.
Use this tool at your own risk. I'm also not responsible for Bricking your device!
Feature List:
First this app is for cooking ROFS2, ROFS3. Core is only supported for extraction and file viewing. UDA isn't supported, use Szakalit's tool for that
Plus, this tool detects which ROFS images are editable! So users of all phones are encouraged to test if they can cook their phones ROFS
1- Cooking is entirely done (restricted) inside the app
2- Fast opening of Firmware Files (fpsx, v**, C00) through dragging and dropping them onto the left pane.
3- The possibility to open an entire firmware folder and choose desired file from the list
4- Fast File/Folder search engine without wildcards
5- Supports reading ROFS partition Size and Available Free Space
6- Supports dragging and dropping of multi files/folders into the app to add them to the firmware or overwrite existing ones
7- Updates available Free Spare on the fly after the addition or deletion of files/folder
8- Warns user about oversized ROFS partition
9- Supports renaming files
10- Support the possibility to open Files with their associated program or by using Notepad or by defining user's own HexEditor
11-A very simple yet intuitive GUI with many detailed information
12- Currently supported phones: 5530, 5800, N97, N86.
13- Other phones like 5320, 6650 are supported but these phones have internal ROFS protection (like 5800's Core file)
Features to come:
1- Exporting and importing changes for easier firmware rebuilding
2- RFOS partitioning if Fully Cracked!
Đầu tiên ứng dụng này là dành cho ROFS2 nấu ăn, ROFS3. Core là chỉ hỗ trợ cho khai thác và xem tập tin. UDA không được hỗ trợ, hãy sử dụng công cụ Szakalit cho rằng
Plus, công cụ này phát hiện đó có thể chỉnh sửa hình ảnh ROFS! Vì vậy, người sử dụng của tất cả các điện thoại được khuyến khích để kiểm tra nếu họ có thể nấu ăn điện thoại của họ ROFS
1 Nấu ăn - là hoàn toàn thực hiện (giới hạn) bên trong ứng dụng các
2 - Fast mở vững Files (fpsx, v **, C00) thông qua cách kéo và thả chúng vào khung bên trái.
3 - Khả năng để mở một thư mục toàn bộ phần vững và chọn tập tin mong muốn từ danh sách
4 - Fast File / Folder công cụ tìm kiếm mà không có ký hiệu đại diện
5 - Hỗ trợ đọc thước phân vùng ROFS và sẵn Free Space
6 - Hỗ trợ kéo và thả các tập tin đa / thư mục vào ứng dụng để thêm chúng vào phần vững hay ghi đè lên hiện tại
7 - cập nhật sẵn Miễn phí phụ trên bay sau khi thêm hoặc xóa các tập tin / thư mục
8 - cảnh báo người dùng về phân vùng ROFS quá lứa
9 - Hỗ trợ đổi tên tập tin
10 - Hỗ trợ khả năng mở tập tin với các chương trình liên quan của họ hoặc bằng cách sử dụng Notepad hoặc bằng cách xác định HexEditor của riêng của người sử dụng
11-A rất đơn giản nhưng giao diện trực quan với nhiều thông tin chi tiết
12 - Hiện nay các điện thoại hỗ trợ: 5.530, 5800, N97, N86.
13 - Loại khác như điện thoại 5.320, 6650 được hỗ trợ nhưng các điện thoại này có nội ROFS bảo vệ (như tập tin lõi của 5.800)
Đến các tính năng:
1 - Xuất khẩu và thay đổi phần vững, nhập khẩu cho xây dựng lại dễ dàng hơn
2 - RFOS phân vùng nếu Fully Cracked!
DOWNLOAD:
