Skype for Symbian - Nâng cấp lên bản 1.1
TruongHan
Super V.I.P
Skype đã nâng cấp lên 1 phiên bản mới cho dòng Symbian.Trong phiên bản này đã được tập trung vào việc cải thiện các tiện ích cũng như trải nghiệm hoàn toàn mới cho người dùng Skype.Phiên bản nâng cấp này hỗ trợ cho Sony Ericsson Satio, Vivaz, Vivaz và các models mới của Nokia.Hỗ trợ đầy đủ cho cả dòng touchscreen và non-touchscreen
Improvements:
* Added support for new device models : Sony Ericsson Satio, Vivaz, Vivaz Pro, added additional Nokia phones to supported list.
* Improved performance during signing in.
* Reduced power usage up to 20%
* Overhauled the user interface
* Added support for showing your phone number as SMS sender.
* Added option to choose time frame for remembering history on the device.
* Added option for setting default file receiving location.
* Skype now stores your prefered connection option.
* Added option to turn Audio/ Vibration notification on and off (Vibration notification respects phone profile settings.)
* Added support for showing flags in Instant Messaging window for touchscreen devices
Fixed issues:
* Fixed issue with displaying native address book contacts in Contacts view.
* If no subscription was purchased, the Subscription status in My Info displayed the Skype Credit expiration date.
* The custom voicemail greeting could not be deleted on touchscreen devices.
* The word “Notification” was not localized on touchscreen devices.
* Skype, on Nokia N78, crashed if the user tried to save a network connection as the default. This behavior has been changed in version 1.1.
* When receiving a file while Skype was running in the background, file receiving was cancelled on Nokia N97 and N97 mini.
* Verified mobile phone number was not carried over from another Skype client to Skype for Symbian.
Known issues:
* On Nokia E71 automatic switching to number input in dial numbers field does not happen on devices with QWERTY keyboard
Current solution: User need to switch input type manually via keyboard key
* Unblock option is missing from Contact list on non-touchscreen devices
Current solution: User needs to un-block contact from desktop client.
* With non-touchscreen devices no error message is displayed if new account is created with empty email field. Error icon is still displayed besides e-mail field
Current solution: None available
* Voicemail playback audio is mixed with regular PSTN call on Nokia E72
* No volume control via Hardware keys on Nokia N95
Current solution: Volume can be controlled by pressing Joystick left or right.
* Sign out cannot be completed if initiated when client is not connected to network
Current solution: Reconnect manually before signing out or exit client.
* On Nokia touchscreen devices voice is lost if SMS is received during a Skype call
Current solution: Voice can be reactivated by putting the call on hold or sometimes switching between loudspeaker and phone.
* On touchscreen devices widget backgroup uses wallpaper picture if it has been set instead of theme background
* Can’t sign for the first time when ‘Ask when needed’ is selected at connection prompt.
Current solution: Add Wlan of 3G access point to a Destination before starting the client.
* Text in input fields on sign in/new account is unreadable on Sony Ericsson Vivaz, Sony Ericsson Vivaz Pro, Sony Ericsson Satio with default black theme. Text is white on white or bright gray background is totally invisible.
Current solution: Default theme issue with color scheme. Usage of other theme resolves this problem.
* On touchscreen devices client tabs are not refreshed if theme is changed during client runtinme. Sony Ericsson only: Icons and tabs in client may disappear during client first start after theme change during client runtime.
Current solution: Device firmware problem, cannot be fixed in client. Restarting or opening/closing client resolved this problem.
* Password entry not masked while entrying it via virtual keyboard on tochscreen devices
* If two online numbers are purchased for an account and each has a different expiry date, the correct expiry date is shown for only one online number
* In some cases the user’s voicemail greeting type (custom or default) is not displayed correctly
* Using the Accept button to accept a sent file does not work on Nokia 6730
Current solution: Use the middle software key to accept a file.
* When answering an incoming phone call whilst listening to Skype’s voicemail, the audio of both will be mixed on Nokia E72
* On Nokia 5800 calling fails on devices with initial firmware release
Current solution: Update your phone’s firmware.
* Occasionally, the call end button does not respond to key presses during a call on Nokia N97 and N97 mini
Current solution: Updating your phone’s firmware will improve the experience.
* It may be confusing that when sending an IM or SMS, the text entry field begins with the word “Password:” on Nokia 5530
* Application may crash occasionally after first start on Nokia N85
Current solution: Upgrading the phone’s firmware to the latest release reduces the risk of crashing.
Hỗ trợ các dòng máy V5 :
Nokia N97
Nokia N97 mini
Nokia 5530
Nokia 5800
Nokia X6
New models supported in this version:
Nokia 5230
Sony Ericsson Satio
Sony Ericsson Vivaz
Sony Ericsson Vivaz PRO
DOWNLOAD
mình mới chuyển sang dùng nokia lần đầu tiên, cho mình hỏi : mình down soft về rồi làm thế nào để cài ?, mình dùng N97, thanks
File bạn down về là file .sis,bạn chép vào thẻ nhớ,vào quản lý tập tin và click vào file đó để cài đặt
@truonghan: thanks bạn, bạn cho mình hỏi thêm là mình cài PC suite 7.1 rồi, sao khi cắm cáp usb vào máy tính nó cứ hiện là thấy thiết bị nhưng ko kết nối là sao vậy, bạn có thể giới thiệu thêm cho mình 1 vài link bài viết hay về N97 nhé, thanks
Bạn vào web Nokia, down cái Nokia Ovi Suite ( bản mới nhất....mình quên phiên bản bao nhiêu rồi )...Mình khuyên bạn không nên xài cái pc Suite....nó kém cái win lắm....lúc này lúc nọ...lúc nhận DR thì lại thiếu nên cứ chớp Dr mãi......và cái Nokia SU....( không cần thiết nhưng thôi có khi bạn xài đến nó trong 1 số việc cũng quan trọng.....) bạn kết nối dt với pc ở chế độ pc suite sau đó chờ cái NOV nó khởi động tìm device rồi nó tìm đt cho bạn....
còn link hay cho N97 thì bạn cứ tìm lòng vòng trong khu vực symbian S60v5 này rồi tìm hiểu....thích cái nào bụp cái đó.....cái nào cũng có cái công dụng và hay riêng của nó hết....
Chúc thành công........
Máy N-5530 EM , khi cài đặt ,báo tập tin bị lỗi . có ai bị như tôi khg ? xin chỉ cách khắc phục , cám ơn !
