UCWEB-7.4.057 beta,Trình duyệt web,wap nhanh va tiết kiệm
phuonxinh
UCWEB-7.4.057 beta,Trình duyệt web,wap nhanh va tiết kiệm​
phiên bản beta này có khá nhiều cải tiến ,a e vui lòng dịch tự dịch (đây là bài giới thiệu bằng Tiếng Anh trên 4rum ucweb)
Mã:
[b]
Test focus: WAP2.0 analysis.
Functional development and optimization:
1.WAP2.0 optimization, a new analysis engine, support more dazzling effect.
2. Skins optimization, the menu is more convenient to use.
3. To increase the default setting to download call UC Thunder
4. Camera function optimization, support zoom function
5. Input box Search Box from the painting, more convenient to input use (V5)
6. Search Results page opens a new window
7. Bookmarks interface, interface and other UI effects optimization history
Main bugfix
1. To solve wap site lost map problem arise.
Known Issues (Do not report the following problems)
1.V5 click on input box and search box will be flashed, filling the system, the proposed system for a light color theme can be temporarily resolved.
2. Sina 3G version of the upper-left corner of the picture shows bad, is restoration.
3. Spacing wap site failure, post will do to improve.
4. Select the box to restore the site to the real effect, selected, only the box, and other sites to show how the definition of what.
5. Theme files and ucs video feeds will not call the Thunder download.
6. In the past saved UTHM format, 7.4 can not open properly.
7.V5 help documentation errors, late replacement will do.
8. Part of the model home problems would be fixed.
This version need an your phone imei number for registrasion. How to register it?
Its simple.
1. Unpacking the sis file using sisboom (on Phone) or unmakesis (on PC).
2. use latest zntxhan to decompres UCWEB60signed.exe
3. After decompression rename Ucweb60signed_unpack.exe into ucweb60signed.exe
4. Open the exe file with zntxhan in mode Hexadecimal way.
5. Press menu on zntxhan>start>edit>search>UTF 8.
6. Search for this imei number "004400701690172". 7. After you got that imei number press C button to removing.
8. Then press menu>edit>insert>put your Phone imei and save your work.
9. After it done, repacking again into sis file using sisboom.
note: this methode only for Hacked/unlocked phone.
[/b]
Bản này là bản beta, mình đã chuyển qua server EN tuy nhiên khi khởi tạo xong nó vẫn sẽ báo là khởi tạo thất bại nên để khắc phục ćác bạn down bản 7.3 cài trc và cho nó khởi tạo xong rùi cài đè bản 7.4 này lên là xong. Bản 7.3 các bạn qua đây down về nhé:http://www.pdaviet.net/attachment.php?attachmentid=176159&d=1279945995
*DOWNLOAD: UCWEB-7.4.057 beta
em mới test xong ,cài vào thì dt chạy hơi chậm, duyệt cũng khá nhanh , nhưng ko nghe nhac online dc , tiếc thiệt !
hjk ,tập tin 7z có 1.1M mà kug ko cho đính kèm ,chán thật. Làm em mất toj hơn 1M gprs.
Em đã up lên host free rùi đó, mọi người test thử nhé. Chú y làm như em đã hd lúc cài đăt ý.
Bản này có nhiều đổi mới tuyệt lắm
