[HOT] 1 DVD ebook, clip, tool, tip, trick...for Hacker & Cr@cker
  • Thread starter Thread starter pdpd
  • Ngày gửi Ngày gửi
pdpd
Trong DVD này có đủ thứ ebook, video, tut, tip, trick...cho các bạn nào tìm hiểu về hacker và Cr@cker. DVD này mình ghi lâu rồi và xem nhiều lần nên nó hơi củ, nên backup lại và share cho các bạn.
Nhớ thay kí tự @ = a trong link download
Post vài tấm hình cho các bạn xem
File type: ISO
Download Here
Mã:
Thay @=a
http://rapidshare.com/files/117434618/Hack___Cr@ck.iso.001
http://rapidshare.com/files/117434782/Hack___Cr@ck.iso.002
http://rapidshare.com/files/117434857/Hack___Cr@ck.iso.003
http://rapidshare.com/files/117434926/Hack___Cr@ck.iso.004
http://rapidshare.com/files/117435003/Hack___Cr@ck.iso.005
http://rapidshare.com/files/116409322/Hack___Cr@ck.iso.006
http://rapidshare.com/files/116812381/Hack___Cr@ck.iso.007
http://rapidshare.com/files/116419095/Hack___Cr@ck.iso.008
http://rapidshare.com/files/117435576/Hack___Cr@ck.iso.009
http://rapidshare.com/files/117435588/Hack___Cr@ck.iso.010
http://rapidshare.com/files/116880637/Hack___Cr@ck.iso.011
http://rapidshare.com/files/116899503/Hack___Cr@ck.iso.012
http://rapidshare.com/files/116908930/Hack___Cr@ck.iso.013
http://rapidshare.com/files/117438863/Hack___Cr@ck.iso.014
http://rapidshare.com/files/116414794/Hack___Cr@ck.iso.015
http://rapidshare.com/files/117438899/Hack___Cr@ck.iso.016
http://rapidshare.com/files/117438945/Hack___Cr@ck.iso.017
http://rapidshare.com/files/117438982/Hack___Cr@ck.iso.018
http://rapidshare.com/files/117439078/Hack___Cr@ck.iso.019
http://rapidshare.com/files/117435078/Hack___Cr@ck.iso.020
http://rapidshare.com/files/117439067/Hack___Cr@ck.iso.021
http://rapidshare.com/files/117439210/Hack___Cr@ck.iso.022
http://rapidshare.com/files/117439457/Hack___Cr@ck.iso.023
http://rapidshare.com/files/117439633/Hack___Cr@ck.iso.024
http://rapidshare.com/files/117439636/Hack___Cr@ck.iso.025
http://rapidshare.com/files/117435698/Hack___Cr@ck.iso.026
http://rapidshare.com/files/117435715/Hack___Cr@ck.iso.027
http://rapidshare.com/files/117438723/Hack___Cr@ck.iso.028
http://rapidshare.com/files/117438751/Hack___Cr@ck.iso.029
http://rapidshare.com/files/117438803/Hack___Cr@ck.iso.030
http://rapidshare.com/files/117435179/Hack___Cr@ck.iso.031
http://rapidshare.com/files/117435271/Hack___Cr@ck.iso.032
http://rapidshare.com/files/117435319/Hack___Cr@ck.iso.033
http://rapidshare.com/files/117435417/Hack___Cr@ck.iso.034
http://rapidshare.com/files/117435485/Hack___Cr@ck.iso.035
http://rapidshare.com/files/117124675/Hack___Cr@ck.iso.036
http://rapidshare.com/files/117177970/Hack___Cr@ck.iso.037
http://rapidshare.com/files/117217341/Hack___Cr@ck.iso.038
http://rapidshare.com/files/117441703/Hack___Cr@ck.iso.039
http://rapidshare.com/files/117439227/Hack___Cr@ck.iso.040
http://rapidshare.com/files/117439367/Hack___Cr@ck.iso.041
http://rapidshare.com/files/117439359/Hack___Cr@ck.iso.042
http://rapidshare.com/files/117439469/Hack___Cr@ck.iso.043
http://rapidshare.com/files/117493405/Hack___Cr@ck.iso.044
http://rapidshare.com/files/117439871/Hack___Cr@ck.iso.045
http://rapidshare.com/files/117441550/Hack___Cr@ck.iso.046
No pass
Down về xong,Sử dụng FFSJ hoặc Hjsplit...để nối file lại, sẻ được file ISO, mount file ISO này ra DVD ảo hoặc sử dụng Ultra ISO...để trích xuất dữ liệu trong file ISO hoặc ghi ra DVD.
Dowload FFSJ
Mã:
http://www.jaist.ac.jp/~hoangle/filesj/
Bạn phải dán link vào trình duyệt sau đó mới down được nhớ thay Nhớ thay kí tự @ = a trong link download
File iso có dung lượng khoảng 200mb, khi mount được 2 thư mục HACKER và CRACKER, thư mục hacker bị lỗi không đọc file được, thư mục cracker đọc bình thường, mặc dù vẫn hiện đầy đủ file. Bạn up lại thư mục HACKER được không? Có thể trong quá trình nén bị lỗi rồi. Thank trước!
Không biết trong quá trình down có gặp lổi gì không, chứ trước khi up mình đã test rồi.Bây giờ cũng đã gần 400 lượt down rồi mà mọi người xem bình thường không có ai bị lổi cả chỉ có riêng bạn thôi. Mình đã PM cho bạn rồi bạn xem nhé.
Thank you.
Đúng là ko dow được bạn ạ mình bấm vào pentium hay free đều ko dow đc luôn.Bạn có thể chia sẻ ở địa chỉ nào dễ dowload hơn ko?
Cái này làm pà con hào hứng quá mà chưa thấy hồi âm gì cả.Pác nào có những cái tương tự như thế thì đưa lên chia sẻ với pà con nào!
