Ntv_79 ơi vào xem Hegazy Ultimate N97 V4.0 Rm-505 V22.0.110
hunganhlove
Lang thang trên mạng lụm được cái này, Ntv_79 vào xem và cook lại cho anh em sài nhé
NOTE:
These are custom firmwares. Only use J.A.F. to flash your phone, using any other flasher like Phoenix will make your phone to be dead.
Add Restart Instead Of Power Off :- When pressing Power Button For Long Time Phone Will Restart Fastly To Shut It Down Shut Press Power Button For once And Chose Power Off.
Don't Run Install Server Patche Coz I Made It Built In With System And But It So It's Working For Ever Even Without RomPatcher Installed
You Can remove Time And Profile Widget From Home Screen
Change Log From v3.0 To v4.0 :
1- Moved Browser Cache To C For More Smoother And Performance.
2- Add Api Bridge v1.1 (Used For Some App Like Ovi Store, ... Etc.
3- Making Mod Max Fps 28 100% Working
4- Improved Accleration More Than Before ( Moved App Cache To All Drives For Over All Performance).
5- Add Auto Installer V1.20 In Z Drive
6- Update RAMblow From 1.0 To 1.30 And Still Have To Disable Open4all Patch Before Use.
7- Add Winrar V 1.1 With System Plugin So You Can Open Any Rar File Form Any File Browser Defult By System
8- Add Accl Switch v1.0 'So Now You Can Turn On/Off Accleometer Sensor By Only One Touch .
9- Decreased System Responce Time So You Can Feel How Fast Is Your Phone.
10- Restart Time Is Decreased "Also So Enjoy Fast Reboot.
11- All Known Bugs Are Completely Fixed And Totaly Improved.
12- Add Install Server Patch With AutoRun ( For People How Have problems With Built In install Server ) 100% Working .
13- Light Intensity set to 10% light by default (For More Bettary Life ).
Wait Feeds Back Again Thanks For Support
Hegazy Ultimate N97 v4.0:- The Fatest Fully Working CFW You Will Ever Met
- Disabled StartUp Light For More Bettary Life Saver
- Auto Lock Touch Screen Set to 30 Sec By Defult
- Brightness Is Set to The Lower Lever For More Bettary Life
- Camera : When Open The Camera Lens Cover You Have To Press The Camera Button For 1Sec to Open
It's Not Bug I Do That So You Can Open Any Torch App Freely Without No Bugs
After You Press Camera Button You Can Take Any Photos And Then Close The lens Cover It Will Normaly Close The Camera App
So The Cover Is Working In Closing Camera Only Not Oppening It.
- Increasing Auto Rotate Sensor Rsponse
- Prevent UnNessesry App From Start Uo To Get More Ram Space
- Voice Command Is Completley Disapled But You Can Start It Manually To Gaint More Ram.
- Audio Plugins Is Set With High Codecs.
-:ALL LANGUAGES SUPPORTED:-
MUST!!!!! READ THIS NOTICES BEFORE DOWNLOAD!!! IGNORING THIS, YOU GET NOTHING!!!!
1) Hard reset very needed to avoid conflict of homescreen and apps installed
2) Format MMC is recommended or just delete E:\private E:\sys E:\system E:\resource E:\patches and F:\private F:\sys F:\system F:\resource F:\patches
3) Delete Any _PAIbTN Folder For Images In E:\Images F:\Images
4) Please Leave Your Phone 7 Min After Flashing Or Hard Reset.
-:CHANGELOGS FOR Hegazy Ultimate N97 v4.0 :-
-:APPLICATION AND SETTINGS:-
THEMES:-
- Defult Theme "Fresh Full Version" From N8 With Ultimate BackGround
- Nokia Theme White From C6
Rompatcher+ v2.3 :-
Remove Recorder Tone Auto On
Open4all+ Auto On Must Be Disabled Before Using RamBlow To Prevent Phone From Restarting
Read CRoot Disabled
C2Z Disabled
C2zBin Disabled
Disable Red Light For Videos And Images Disabled
Active Bass Effects Disabled
BlueTooth Locker Disabled
- All Patches Tested And Working Prefectly
Application You Get With Hegazy Ultimate N97 v3.0:-
1- X-plore 1.51 Full Cracked One Icon Only
Show hidden files automatically
Show RAM Drives automatically
Show system files/folders automatically
Sort by: Extension automatically
Use system font automatically
2- Touch Restart If Power Button Didn't Response ( Built In SoftWare Can't Be Deleted )
3 - Qiblah Direction V1.0 To Know The Direction Of Qiblah Befor Pray.( Built In SoftWare Can't Be Deleted )
4 - Phone Torch V1.0 ( Switch Of From Dual Led Flash To Red Light And Vis Versa And Also You Can Sent Morse Code By Flash From It)
5- Photo Prowser v0.95 With Photos Plugin Defult Photo Browser You Can See The App In Photos Also ( Built In SoftWare Can't Be Deleted )
6- WinRar Plugin v1.0 ( Built In SoftWare Can't Be Deleted )
7- Unistall King v1.2.0 Can Be Upgraded With Any Version But You Will Not Use It Coz Defult Unistaller Working Perfectly With Option To Close Running App When Removing It
8- RamBlow V1.0 Fully Working Cracked Without Any Bugz And Can Be Updated And Removing If You Wish ( Not Built In SoftWare Can Be Deleted )
9- Kill Me To Show Open Process And App And Terminating What You Want Can Be Updated And Deleted If You Want .
10- Screen Snap v1.0.
Image type: Jpeg - High Quality set automatically
Base file name: Pirate set automatically
Storage: Memory card set automatically
11- Ultimate Voice Recoder v6.2.1 To Record Voice Calls Without Beeb
12- NsysInfo Gets Every Possible Information About Your Great N97 Device. ( Built In SoftWare Can't Be Deleted )
13- Hand Writing Calculator Fixed 2 Form Nokia For HandWriting Math Calculating Can Be Updated And Deleted .
14- Adope PDF Is Cracked For Ever (Unlimited Trial Period)
15- Nokia Notification Widget For Home Screen Show Your Message And Missed Calls
16- Conversation App Make Your Messages Like Iphone.
FEATURED:-
- Remote Lock still enabled
- Voice Command still Disabled
- Nokia OVI Welcome (My Nokia) Disabled
-:MODS:-
SYSTEM CACHING AND PERFORMANCE:-
- Fonts Version Updated (Replaced by C6 fonts).
- Running application will cache in All Drivers For Better Berformance
- RAM totally Optimise at startup
- Some Apps totally disabled on startup
- Improved Increases system memory heap size
- Decreases application delay and close time taken by apps
- Improved UI Acceleration .
- Improved Rotation Speed.
- Improved Scrolling Speed With Fixed Menu Lag
- Disabled Speed Scrolling In Short Lists
- Improved Camera Photos (Disabled Compresstion Of Photoa You Got About 2M For Photo But It's Worth)
- Improved Video Capture .
- Improved Video Call Quality.
- Browser cache moved to E:\
- Max fps increased from 22 to 28.
- Prevented apps to run in background (messaging,log,contacts,...).
- Improved WiFi sensivity.
- Dictionary Arabic Language.
Call:-
- Summry After Call Set On By Defult
- Show Call Duration Set On By Defult
AUTO MAKE/COPY FOLDERS:-
- E:\thinkchange\c
- E:\thinkchange\e
- E:\Music
- E:\patches (auto copy patch)
- E:\Recevied
- E:\system\Cache
PATCHES:-
Read CRoot Disabled
C2Z Disabled
C2zBin Disabled
PERSONALISATION:-
- Shutdownscreen : Hegazy Bios Ultimate ShutDown
- Splashscreen : Hegazy Bios Ultimate StartUp
- Bootscreen: Hegazy Boot Screen
- Shutdown image removed for faster shutdown
- Alarm Snooze interval is set to 7min by default
- Light Intensity set to 50% light by default
- Theme Effects: Swip And Rotate Full And Working Smoothly
INSTALLATION:-
- SwiPolicy changed which enable to install almost apps without installserver patch
- Remove annoying widget security during installation of sis, sisx
- Secure Widget Preinstall will not run on first startup.
- Java permission is Set To Always Allowed
- Install Server.exe Installing Any App Without Certification (No Error In Certification ) By Defult Even If All Patches Disabled
BlueTooth:-
Press 0 To Switch On / Off Bluetooth ( Built In SoftWare Can't Be Deleted ) Have Fun With That.
SECURITY:-
- Automatic lock phone in 30 seconds by default
- Auto Dim Screen Light After 15 seconds by default
- Maximum automatic lock phone can be set up to 10 minutes
- Flash Player Working Correctly
MENU AND SENSORS:-
- Tapping Mode added: shake to get phone silent/snooze alarm .
CONNECTIVITY AND BROWSER:-
- Nokia Default Internet Browser can go landscape with turning control OFF
- Auto Resume Download manager will be started on browser start-up to resume
- Nokia default file browser can send sisx, sis, jar and any protected items via bluetooth, mms and uploads
- Nokia default file browser will open private, sys, C: root folder
- FOTA reserved spaces in C: deleted: gain 5MB
- Bookmark Edited And Deleted
MESSAGING, CONTACTS AND HIDDEN APPS:-
- Message to My Nokia will not send on startup
- Delivery reports set to on by default
- No. of message sent saved increase from 20 to 999 by default
- Ovi Contacts totally disabled
CAMERA:-
-When Opining Lens Cover Camera Will Not Open I Made That So You Can Start Any Torch App
After Opening Camra Lens Cover Press On Camer Button Untill It's Opening Close Camera Cover It Will Close Cam App Normaly
That Means It Working Succesfully.
- Camera sound is disabled In Photos When Choosing Camera Sound No.1 ( Defult ) Even If Warning Sound Set To On
- Video Recording Tones Is Completely Disabled (Start/Pause/Stop)
- Camera will not leave in background after close it (SAVE RAM)
VOICE RECORDING AND VOLUME:-
- All automatically set to the highest quality
- Now you can record up to 12 Hours
- Internal speaker automatically set to maximum when calling
- Loudspeaker automatically set to normal 5/10
- Bootscreen volume slowed: Normal volume
- Voice recording during call fixed
MUSIC PLAYER AND GALLERY:-
- Put all songs file in E:\Music and F:\Music
- Music player only read E:\Music and F:\Music location
- Faster to refresh
- Gallery Improved to find files
- Ringtones :-
N8 & C6 Defult Ring Tones And Also Add To Genral With Defult Message Tone For N8 Also By Defult
Change All Alarm Tones To Nuclear Alarm Tone By Defult
you can find them in profile settings
OVERVIEWS FOR NOKIA N97
- RAM after reboot: 61.53 mb
- RAM after clean up: 59.9 mb
- C: drive space after reboot: 64.2 mb - RAM experinces may different due to language in rofs2
To Download
http://www.4shared.com/file/EibTX_D2/Hegazy-Ultimate-N97-v40-Rm-505.html
Cái này có lâu rồi một bản Ultimate và một bản lite nhưng mình thấy không có gì đặc biệt cả bạn à! Bản này tích hợp quá nhiều phần mềm vào room, đó là cái dở nhất đó bạn à> Còn những cái khác thì không bằng các bản mình đã cook đâu! Thôi cứ để cho mọi người cùng tham khảo cũng tốt!
ừ bản 7 của bạn máy chạy rất nhanh, mà tức mổi cái là N97 hiệu ứng bỏ vào nhiều quá gây lag khi vào setting... C6 mình cũng bỏ bấy nhiêu hiệu ứng mà nó chạy nhanh hơn. ức chế quá
