TP.HCM Samsung Galaxy Note 3 SM-N900 4.4.2 Unlock Ok !
  • Thread starter Thread starter Taki7610
  • Ngày gửi Ngày gửi
Taki7610
Unlock_GSM
Mã:
To connect SGH-I747 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#7284#" number.
12. Set "UART" to "PDA" value.
13. Restart phone.
14. Press "Read Info" in software.
To connect SM-N900 phone you have to perform the following steps:
Platform: Samsung Android
Selected port: COM19
Selected model: SM-N900
Port is busy
Searching for a phone. Please wait...
Phone was not found on the selected port!
Searching for USB diagnostic port...
No diagnostic ports found!
Connecting to phone on COM5
Phone connection failed
Selected port: COM283
Phone found.
Firmware compiled date: Thu Apr 17 18:28:18 KST 2014
PDA version: N900UBUDND1
CSC version: N900UUBDNC1
SW version: N900UBUDNC1
Phone IMEI: 352746065960371
Phone SN: RF1F42XBYYB
Android version: 4.4.2 (KOT49H)
Detected phone model: SM-N900
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N900-Unknown02-06-2014_13-37-57-.asec file
Cheking security type...
New security type is detected
Executing exploit...
Exploit has been executed successfully
Unlocking phone. This can take some time. Please wait...
Phone is successfully unlocked
To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!)
