XBmod Manila Rhodium VGA Port (BETA 1) + FIX V1c
  • Thread starter Thread starter ntt2006
  • Ngày gửi Ngày gửi
ntt2006
XBmod Manila Rhodium VGA Beta 1c
MANILA_CAB_PACKAGE WWE +fix V1c
(File nằm trong Link down cuối bài)
Contain the following cabs:
Rhodium Manila--HTC New ContactCard
HTC Notification--HTC Menu Enhancement
Rhodium volume control & some tweak
FIX V1c:
Fix crash on all people Tab.
Fix Landscape people tab
Fix scroll people detail
Fix people details landscape
fix SMS crash
Fix SMS scroll & sendbox
Stability Improved
Contact pictures link fix (V1c)
-Disable Manila reboot then install Fix
Install Start menu fix.cab if new manila start menu don't work
MANILA LANGUAGE PACK:
Contain the following languages:
ca-es--cs-cz--da-dk--de-de
el-gr--es-es--es-es_tradnl
fi-fl--fr-fr--hu-hu--it-it
ja-jp--ko-kr--nb-no--nl-nl
pl-pl--pt-br--pt-pt--ro-ro
ru-ru--sk-sk--sv-se--tr-tr
zh-cn--zh-tw
Additionnal languages classified
additionnal_language.cab
(2 File nằm trong Link down cuối bài)
T-Mobile skin ported from Rhodium
Disable Manila, install cab,enable tsk then enable Manila
README
We decided against the traditional readme.txt file because
most people are know it all's and won't read it anyway...
PERFORMING A HARD RESET IS STRONGLY RECOMMENDED BEFORE INSTALL!!!
THIS DOES NOT WORK ON ALL ROMS!! RECOMMENDED 21000+ BUILDS ONLY!!!
I'm going to try to make the installation instructions as simple as possible. This way we don't have noob questions like "How do I install this?".
1. First you need to make the following changes to your settings:
1. Browse to StartSettingsPersonalTodayItems and DISABLE TouchFLO 3D.(See 1st Screenshot)
2. Click ok and go back to the home screen.(See 2nd Screnshot)
3. Now browse to StartSettingsSystemPowerAdvanced and un-check all options.(See 3rd Screenshot)
4. Click ok until you are back on the home screen.(See 2nd Screenshot)
2. Connect your device to ActiveSync and copy the 3 required cabs to your storage card. It doesn't matter where as long as you remember
where they are at. Disconnect from ActiveSync and Soft-Reset.
3. Browse to the place on your storage card where you put the cab files.
1. Install xbmod policy.cab (SOFT-RESET!!)
2. Install XBmod VGA Rhodium Manila.cab (DO NOT SOFT-RESET YET!!)
3. Install HTC New Contact Card.cab - OKAY NOW SOFT-RESET.
4. Browse to StartSettingsPersonalTodayItems and ENABLE TouchFLO 3D.
Fixed:
IF you have a problem with the weather tab crashing after you finish installation...
Delete:
\Application Data\HTC\databases\forecast_cache.db
And Replace(with attached file below):
\Windows\2330fc3c_manila
LINK DOWNLOAD
Nguồn :
Cái này là giao diện TouchFlo 3D hả bạn, nó xài cho màn hình gì vậy, Atom Life xài được chứ?
ntt2006 cho chút tiếng Việt vào chứ cứ copy nguyên bản của xboxmod(xda) thì mấy ai hiểu.
mình nghe thấy bên xda cũng có topic của 1 pác phát triển phần mềm này cho dòng Kaiser, cũng nghĩa là sẽ dùng đc cho QVGA nhưng hiện tại mình chưa thấy thông tin j thêm cả
Đúng vậy,tuy nhiên nó chưa hoàn thiện(by utop).Vả lại QVGA mà chạy cái này chắc sẽ mệt mỏi lắm,Kaiser và Polaris còn đuối...Dù sao đi nữa,đối với dân dùng PPC thì cứ có là vọc cho biết,mình cũng vậy >:)
Bác nào hướng dẫn mình cách cài với. down về có rất nhiều file. Mình làm theo hướng dẫn trong đó thì màn hình PPC của mình chỉ hiện được chữ : tap here to launch TouchFlo 3D, chọt zô thì vẫn thế. Mình dùng Exec. Nhân đây cho mình hỏi có cách nào để cho Manila 2D phù hợp với màn hình ngang không, tức là thanh tab nằm ngay dưới chân màn hình ấy. Giống như mấy cái hình ở trên vậy
Bso tay với cái kiểu đưa topic kiểu này; khác gì đem con bở chợ đâu; trên http://forum.xda-developers.com/showthread.php?t=493531 đã có tới 182 trang ;
Bác này đưa lên cho anh em là tốt nhưng phải nói rõ cách sử dụng; và các bản chuẩn; đánh giá từng bản chứ cái kiểu copy - paste thế này thfi đúng là...
Thông cảm nhé MOD em nói thẳng
