Cook Firmware {Nokia 5800XM v50} by Jack Pham
  • Thread starter Thread starter jackpham
  • Ngày gửi Ngày gửi
Bạn thích nhất là CFW nào của Jack Pham
  • Số thành viên bình chọn
    87
Mình xài 5800 thấy FW cua jackpham đẹp quá, không biết up làm sao. đao v6 về bung nén ra có 2 file, sử dụng làm sao
Mã:
RM-356_50.0.005_C01_prd.rofs3.fpsx
RM-356_50.0.005_prd.rofs2.V20
Một hồi mò mò thấy file
Mã:
RM-356_APAC_50.0.005_v13.0_PDAViet.exe
download về cài thì có thư mục
Mã:
C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\
có phải copy đè 2 file trên vào đây ko. Sory mình gà
Cám ơn bạn, mình đang up thì bị thế này, đợi mãi mãi chẳng thấy gì cả
JAF version 1.98.62
Detected PKEY: 9000A62F
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.29.0
Changing mode...Done!
Detected P-KEY: 9000A62F
Init usb communication...
Found
Init usb flashing...
Reading flashid...
CMT: 00400020 <=> ST -> Type not in database
APE: 00000000 <=> Flash -> not detected
Done!
Searching for phone...Detected P-KEY: 9000A62F
Found
MCU SW version: V ICPR72_10w04.5
22-03-10
RM-356
(c) Nokia
HW version: 1304
PCI version:
RFIC version:
DSP version:
APE SW Core version: V 50.0.005
APE Variant version: V 50.0.005V 50.0.005 V 50.0.005
APE Test version: eno_version
Retu version: 16
Tahvo version: 22
APE HW version: 256
APE ADSP SW version: 256
APE BT version: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
Production serial number: COL511522
Product code: 0573800
Module code: 0204481
Basic production code: 0591285
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 351531044889482
IMEI spare to net: 3A 15 35 01 44 88 49 08
IMEI SV to net: 33 15 35 01 44 88 49 68 F0
LOCK STATUS:
CONFIG KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Reading product code...
Product Code: 0573800
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-356\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_50.0.005_prd.core.C00
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_50.0.005_prd.rofs2.V20
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_50.0.005_C03_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_50.0.005_026_000_U01.uda.fpsx
Languages in ppm: English,Vietnamese,Tagalog,Chinese Simpl,Chinese Trad
Done!
Backing up CRT...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\351531044889482_CRT_backup_215536.pm
Done!
Backup CRT OK!
Searching for phone...Found
Reading SW version...ICPR72_10w04.5 50.0.005
Reading battery value...3732 mV
Reading flashid...
Verifing ADL communication... Status byte 7
Rebooting to flash mode...
Waiting for the phone to reboot...
Sending RAW loader...
Using 009.012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting.................
mình chạy như thế này đúng không bạn?
check vào manual flash và dead usp thì lại bị thế này hic
Backup CRT OK!
Detected P-KEY: 9000DC11
Can't detect flashing server!
bạn coi lại bản down coi dúng ko?? chứ mình làm là nó như này
JAF version 1.98.66 beta5
Detected PKEY: 90009B54
USB Cable Driver version: 7.1.28.1
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: \Products\RM-356\
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_50.0.005_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_50.0.005_prd.rofs2.V20
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_50.0.005_C03_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_50.0.005_026_000_U01.uda.fpsx
có gì đt cho mình coi có giup gì dc ko ?? đt minh : 0983817239
bạn tắt phone đi nha.bật JAF lên chuyển qua tab BB5,chọn các ô dead usb, manual flash,normal mode,bỏ chọn cái ô crt 308 rồi chọn cái ô USE INI lúc này nó hiện lên cái bảng các đời phone mà nó support bạn dùng 5800 RM-356 thì chọn 5800-D1.xong đó bạn chọn cái product code của máy mình.nhấn vào nút flash của JAF.nò hiện thông báo có muốn flash ko?bạn chọn YES.nó báo press power button now tì bạn nhấp nút nguồn một cái.nếu chưa nhận phone thì tháo cáp ra rồi cắm vào lại làm lại từ bước nhấn nút flash đến khoảng 2 lần là nhận phone.bạn nên xạc đầy >70% pin,dùng hub usb đằng sau nha.có gì liên lạc với mình qua Y!M của mình
bạn tắt phone đi nha.bật JAF lên chuyển qua tab BB5,chọn các ô dead usb, manual flash,normal mode,bỏ chọn cái ô crt 308 rồi chọn cái ô USE INI lúc này nó hiện lên cái bảng các đời phone mà nó support bạn dùng 5800 RM-356 thì chọn 5800-D1.xong đó bạn chọn cái product code của máy mình.nhấn vào nút flash của JAF.nó hiện thông báo có muốn flash ko?bạn chọn YES.nó báo press power button now thì bạn nhấp nút nguồn một cái.nếu chưa nhận phone thì tháo cáp ra rồi cắm vào lại làm lại từ bước nhấn nút flash đến khoảng 2 lần là nhận phone.bạn nên xạc đầy >70% pin,dùng hub usb đằng sau nha.có gì liên lạc với mình qua Y!M của mình
bạn ơi cho hỏi chút.nếu mình tích vào ô Factory Set thì có làm sao ko thế bạn?Mình thấy có nhiều bài viết lúc thì có lúc thì không là sao nhỉ?
Bạn sửa tên file cho đúng màu máy của bạn nhé: RM-356_50.0.005_C03_prd.rofs3.fpsx (C01 là màu đỏ, C02 là màu xanh, C03 là màu đen)
Em đang sài bản CFW 6.1 của bác Jack, nhưng khi mình cài SBP mobile thì độ phân giải của màn hình không được đẹp lắm; ảnh người gọi bị nhoè. Bác Jack kiểm tra giúp em nhé !
bạn ơi, bạn cái SBP mobile phiên bản nào thế?up cho mình đc ko?mình cài cai 3.0.259 nhưng mà cài xong thì ko cháy được.máy báo lỗi ko thực hiện đc là sao nhỉ?
Bạn phải chuyển điện thoại sang chế độ tiếng Anh thì sẽ chạy được thôi. Trên diễn đàn cũng có bản Việt hóa rồi đó bạn down về cài xem.http://www.mediafire.com/?zynvmz1qumu#2 hoặc bản tiếng Anh: http://www.mediafire.com/?5tmwgduamny
Key: 8C59-PPVX-2BM4
cái Factory set theo mình có lẽ là khôi phục nguyên trạng xuất xưởng.bạm flash FW ko cần để ý nó.ok.mình bỏ qua vẫn flash ngon lành
anh jack ơi sao em flash xong file gửi qua bluetooth vẫn vào chỗ tin nhắn vậy :( nó không vào trong ổ E hả anh
