CFW ^ 3 v6.1 Symbian For Nokia 5800 5530 5230 X6
chichung781988
Mới lang thang qua bên forum pnht thấy có cái này mới, copy về cho anh em coi...Bác nào giỏi Cook làm cho anh em bản tiếng Việt...Và mod thêm 1 số thứ cần...
Sorry mình kém tiếng Anh nên kô dịch đc, bác nào cần thì xài google đỡ vậy :)
The new update has arrived and with it all the bugs fixed. Version 6.1 has many improvements in performance and appearance changes, but as we know you want to know the changes, here they are:
NEW FEATURES
New effects in the Symbian original interface ^ 3
Ovi Maps 6.3 built-Final (Except 5530)
15.2 music player with built-lyrics (Solution for Latin languages)
Ovi updated v1.09.
Fullset ^ 3 Symbian icons that change according to the theme you set.
Compatible with Ovi Suite 3.
Text of the menu buttons centered as in Symbian ^ 3
New Extended menu, wider!
Greater speed in the movement and application performance
Removed rotation sliding unlock
Fixed error when installing some old songs
Compatible with PhotoBrowser
The battery back to normal ... life improved
Features
Interactive desktop with Widgets
Languages: English and Spanish Latino (5230 5530 5800) and Spanish Spain (X6 5800)
You can install anything you want without signing applications, or perform any process
Never again you will get a certificate expired error!
Integrated mail client with HTML support and compatible with your Hotmail, Gmail, Ovi, etc.
Release system by swiping your finger across the screen.
New font much more modern and fitted with the new menu, the original source is huge !!!!!!!!
4x4 menu reorganized and custom folders
Added 3 new widgets shortcuts so you can get full screen access.
79 MB free internal memory (290 MB free X6) and 58 MB free RAM
Clock Widget is now removable so you can remove it and have a Full Swipe
Removed the poster to show all applications running on the drop down menus
Java applications and bring all permits WRT enabled to avoid so many unnecessary requests
You can send any file protected by Bluetooth, no more restrictions
Added new audio codecs for stereo sound better
Sound a lot stronger than the original firmware
Embedded applications Ovi maps, Conversations, Notifications.
In the Ovi mobile is identified as a Nokia N97 so have many more programs compatible
Improved effects and without delay
Facebook added tactile equipment browser bookmarks
Gallery reconfigured to not read images in system folders
Dark S60 startup image and sound a bit low not to disturb
Removed some startup applications to have more free resources.
Browser Cache grown and moved to E
VERSION
FIRM BASE
WHO CAN USE THE
SYMBIAN ^ 3 v6
NOKIA 5230 RM-594
Only v21.8.005 RM-594 with the same firmware version
SYMBIAN ^ 3 v6
NOKIA 5530 RM-504
5530 v32.0.007 all regardless of version
SYMBIAN ^ 3 v6
NOKIA 5800
RM-356
All 5800 v52.0.007 RM-428 whether or RM-356 no matter which version
SYMBIAN ^ 3 v6
NOKIA RM-559 X6
All 31.0.004 RM-559 X6
The RM-551 with versions less than or equal to v30
FREQUENTLY ASKED QUESTIONS
How do I install?
Here we explain step by step tutorial with pictures and even video anti Dummies:
INSTALL A MODIFIED IN YOUR NOKIA FIRMWARE
WHAT HAPPENS IF I CHANGE RM?
The MR differ only in the languages ​​of each mobile and firmware RM-428 is originally American English language, Spanish, Latin, Portuguese Brazil and others, while the RM-356 is British English, Spanish, Spain, Portugal and Portuguese; so if you change your RM only change the languages ​​available and before you ask, YES ... your 3G will work as usual.
RM CHANGE HOW?
You need not do anything before, just flash when you select in the JAF MRI are going to call, say if you have a Nokia 5800 RM-428 to install this firmware you must select the RM-356 flash when the JAF and that's all.
CAN I GO BACK TO MY ORIGINAL RM?
Yes, you can simply re-flashing with the same version you have but it is for your MRI, what happens is that Nokia has abandoned the RM in the Americas and is only getting updates for Europe, and across all the major advances in CFW RM only leave for European
so think twice before returning to your RM American, we do not recommend!.
LOVE ME IF I CAN NOT RETURN TO ORIGINAL OR PUT ANOTHER FIRM CFW?
Yes, you can always put another CFW that is based on the same version of firmware that CFW. Likewise, you can return to the original version in the same versions.
"ALWAYS APPLICATIONS ARE COMPATIBLE WITH THIS CFW?
Of course, if all your applications are compatible, but we recommend that henceforth seek applications for the N97 or the C6 and some bring the plugin to put a widget on the desktop, down on the extras will leave you some. The themes are also compatible but do not bring the oldest mark button so we recommend you install themes designed for the N97 or search for the newest ... We put a new theme every weekend!
CLARIFICATIONS
Before writing that there is an error, please check before you formatted flash external memory and I did a Hard reset (* # 7370 #) to your mobile, 99% of problems are solved that way.
Nokia Messaging: Does not support, we will delete all Nokia components Messaging and still is not compatible ... continue working on it.
Activating effects: Settings> Themes> General> Options> Theme Effects / Activate
Support Contacts: If you make a backup with the Ovi suite will have problems, so the process to follow to keep all your phone numbers is:
From your phone go to your address book, press Options, where it says you give DIAL-> Mark all. Then press Options again and give in the BUSINESS CARD COPY -> In another report, choose your external memory and ready.
When you've got your Symbian phone with our CFW ^ 3 v6 installed so you just go to your address book again press Options, then BUSINESS CARD -> On the other memory and select your external memory. This method is not only much easier and faster but it also is much more complete because all pictures are saved contact and everything is done from the same phone.
Enable Rotation: Settings - Phone - Conf sensor - control activation - Auto Rotate Screen
Stamps: The stamps you put on your external memory in the folder E: / Sounds / Digital
Updates: Updates are already built, please understand that not need to reinstall them.
Sound camera: Camera> Options> Settings> Capture tone> Camera 4
ADVISED BY THE COMMUNITY BUGS
PROBLEM SOLUTION
No green light on the Nokia 5530 We are awaiting confirmation and if a bug is corrected the download package throughout the week. As reported also solved by just changing the subject ...
In the 5800 Latino, not an option to reset the phone That was an oversight on our part and although the text appears, if the integrated function but so correct over the week.
links
Mã:
 http://shareflare.net/download/14405.19959d40cbee4bc91f4814774445/CFW_Symbian_3_v6.1_Nokia_X6.rar.html
http://shareflare.net/download/82529.81bbc6f0a79047786564fccda0a8/CFW_Symbian_3_v6.1_Nokia_5800_RM-356.rar.html
http://shareflare.net/download/89887.86b70e33f22248843caf8b05665b/CFW_Symbian_3_v6.1_Nokia_5800_Latino.rar.html
http://shareflare.net/download/43701.40ac26c32a7b4b415c4fb59e376d/CFW_Symbian_3_v6.1_Nokia_5530.rar.html
http://shareflare.net/download/32959.34aec3369b3be6e2613c2e6817c1/CFW_Symbian_3_v6.1_Nokia_5230.rar.html
Thêm link cho các bạn down load :D
Mã:
CFW SYMBIAN^3 v6 Nokia 5230 [URL="http://www.multiupload.com/TSY4WRSU09"]http://www.multiupload.com/TSY4WRSU09[/URL]
CFW SYMBIAN^3 v6 Nokia 5530 [URL="http://www.multiupload.com/38QSABPL7W"]http://www.multiupload.com/38QSABPL7W[/URL]
CFW SYMBIAN^3 v6 Nokia 5800 RM-428 (poner 356 en el JAF) [URL="http://www.multiupload.com/85HKMRKKBM"]http://www.multiupload.com/85HKMRKKBM[/URL]
CFW SYMBIAN^3 v6 Nokia 5800 RM-356 [URL="http://www.multiupload.com/NWSO563EFH"]http://www.multiupload.com/NWSO563EFH[/URL]
CFW SYMBIAN^3 v6 Nokia X6 (poner 559 en el JAF) [URL="http://www.multiupload.com/VF8BJYCZZW"]http://www.multiupload.com/VF8BJYCZZW[/URL]
Vuducthanh2007 sẽ add TV và làm 1 số mod khác
CFW Symbian ^ 3 v6.1 para Nokia 5800 5530 5230 X6
Bản cập nhật mới đã đến và với tất cả các lỗi cố định. Phiên bản 6.1 có nhiều cải tiến trong hiệu suất thay đổi và xuất hiện, nhưng như chúng ta biết bạn muốn biết những thay đổi, ở đây đó là:
Các tính năng mới
Mới hiệu quả trong giao diện Symbian ^ gốc 3
Ovi Maps 6,3 cuối cùng được xây dựng (trừ 5530)
15,2 nghe nhạc được xây dựng với lời bài hát (Giải pháp cho các ngôn ngữ Latin)
Ovi cập nhật v1.09.
Fullset Symbian ^ 3 biểu tượng thay đổi theo các chủ đề bạn đặt.
Tương thích với Ovi Suite 3.
Văn bản của các nút menu trung tâm như ^ Symbian 3
Mới mở rộng thực đơn, rộng hơn!
Tốc độ lớn hơn trong việc thực hiện phong trào và ứng dụng
Loại bỏ quay trượt mở khóa
Sửa lỗi khi cài đặt một số bài hát cũ
Tương thích với PhotoBrowser
Các pin trở lại bình thường ... đời sống được cải thiện
Tính năng
Tương tác máy tính để bàn với Widgets
Ngôn ngữ: tiếng Anh và tiếng Tây Ban Nha La tinh (5230 5530 5800) và Tây Ban Nha Tây Ban Nha (X6 5800)
Bạn có thể cài đặt bất cứ điều gì bạn muốn mà không cần ứng dụng ký kết, hoặc thực hiện bất kỳ quá trình
Không bao giờ một lần nữa bạn sẽ nhận được một giấy chứng nhận hết hạn lỗi!
Tích hợp mail của khách hàng với HTML hỗ trợ và tương thích với các bạn Hotmail, Gmail, Ovi, vv
Ra mắt hệ thống bằng cách đánh mạnh ngón tay của bạn trên màn hình.
Font mới hiện đại hơn và được trang bị với các menu mới, nguồn gốc là rất lớn !!!!!!!!
4x4 menu tổ chức lại và thư mục tùy chỉnh
Đăng 3 widget mới phím tắt để bạn có thể truy cập toàn màn hình.
79 MB bộ nhớ trong (290 MB miễn phí X6) và 58 MB RAM miễn phí
Widget đồng hồ là bây giờ có thể tháo rời để bạn có thể gỡ bỏ nó và có một Swipe toàn
Loại bỏ các áp phích để hiển thị tất cả các ứng dụng chạy trên trình đơn thả xuống
các ứng dụng Java và mang tất cả giấy phép WRT kích hoạt để tránh quá nhiều yêu cầu không cần thiết
Bạn có thể gửi bất kỳ tập tin được bảo vệ bởi Bluetooth, không hạn chế
Nhập mới audio codec cho âm thanh stereo tốt hơn
Âm thanh mạnh mẽ hơn rất nhiều so với firmware gốc
Nhúng các ứng dụng bản đồ Ovi, hội thoại, thông báo.
Trong Ovi điện thoại di động được xác định là một Nokia N97 để có nhiều chương trình tương thích hơn
Cải thiện hiệu quả và không chậm trễ
Facebook thêm dấu trang trình duyệt thiết bị xúc giác
Thư viện ảnh cấu hình lại để không đọc các hình ảnh trong thư mục hệ thống
Dark S60 khởi động hình ảnh và âm thanh một chút thấp không làm phiền
Loại bỏ một số ứng dụng khởi động để có thêm nguồn lực miễn phí.
Browser Cache phát triển và chuyển đến E
VERSION
CÔNG TY BASE
AI CÓ THỂ SỬ DỤNG
Symbian ^ 3 v6
NOKIA 5230 RM-594
Chỉ v21.8.005 RM-594 với các phiên bản firmware cùng
Symbian ^ 3 v6
NOKIA 5530 RM-504
5530 v32.0.007 tất cả không phân biệt phiên bản
Symbian ^ 3 v6
NOKIA 5800
RM-356
Tất cả 5800 v52.0.007 RM-428 hay RM-356 không có vấn đề mà phiên bản
Symbian ^ 3 v6
Nokia RM-559 X6
Tất cả RM-559 X6 31.0.004
Các RM-551 với các phiên bản nhỏ hơn hoặc bằng V30
CÂU HỎI
Làm thế nào để cài đặt?
Ở đây chúng tôi giải thích từng bước hướng dẫn với hình ảnh và thậm chí chống video Dummies:
INSTALL A FIRMWARE NOKIA SỬA ĐỔI TRONG BẠN
NẾU RM ĐỔI XẢY RA GÌ?
Các MR chỉ khác nhau ở các ngôn ngữ của từng RM điện thoại di động và phần mềm-428 có nguồn gốc là tiếng Anh Mỹ, Tây Ban Nha, tiếng Latin, tiếng Bồ Đào Nha Brazil và những người khác, trong khi RM-356 là tiếng Anh, tiếng Tây Ban Nha, Tây Ban Nha, Bồ Đào Nha và Bồ Đào Nha, vì thế nếu bạn thay đổi RM của bạn chỉ thay đổi các ngôn ngữ có sẵn và trước khi bạn yêu cầu, YES ... 3G của bạn sẽ làm việc như bình thường.
RM ĐỔI THẾ NÀO?
Bạn không cần phải làm bất cứ điều gì hết, chỉ cần flash khi bạn chọn trong MRI JAF sẽ gọi điện, nói rằng nếu bạn có một Nokia 5800 RM-428 để cài đặt phần mềm bạn phải chọn flash-356 RM khi JAF và đó là tất cả.
Anh có thể GO BACK TO RM GỐC CỦA TÔI?
Có, bạn có thể chỉ cần nhấp nháy lại với phiên bản mà bạn có, nhưng nó là dành cho MRI của bạn, những gì xảy ra là Nokia đã bỏ RM ở châu Mỹ và chỉ nhận được bản cập nhật cho châu Âu, và trên tất cả các chính tiến bộ trong CFW RM chỉ để lại cho châu Âu
để suy nghĩ hai lần trước khi trở về RM Mỹ của bạn, chúng tôi không khuyên bạn nên!.
LOVE ME NẾU KHÔNG TRỞ LẠI gốc hoặc PUT HÃNG KHÁC CFW?
Có, bạn luôn có thể đặt một CFW đó là dựa trên cùng một phiên bản của phần vững CFW. Tương tự như vậy, bạn có thể quay trở lại phiên bản gốc trong các phiên bản tương tự.
"LUÔN LUÔN LÀ ỨNG DỤNG tương thích với CFW này?
Tất nhiên, nếu tất cả các ứng dụng tương thích, nhưng chúng tôi khuyên rằng từ nay trở đi tìm kiếm các ứng dụng cho N97 hoặc C6 và một số mang lại những plugin để đặt một widget trên màn hình, xuống extras sẽ để lại cho bạn một số. Các chủ đề cũng tương thích nhưng không mang lại nút nhãn hiệu lâu đời nhất vì vậy chúng tôi khuyên bạn cài đặt các chủ đề thiết kế cho N97 hoặc tìm kiếm mới nhất ... Chúng tôi đặt một chủ đề mới mỗi ngày cuối tuần!
Làm rõ
Trước khi viết rằng có một lỗi, hãy kiểm tra trước khi bạn định dạng bộ nhớ flash bên ngoài và tôi đã làm một thiết lập lại cứng (* # 7370 #) cho điện thoại di động của bạn, 99% các vấn đề được giải quyết theo cách đó.
Nokia Messaging: Không hỗ trợ, chúng tôi sẽ xóa tất cả các thành phần Nokia Messaging và vẫn còn không tương thích ... tiếp tục làm việc trên đó.
Kích hoạt các hiệu ứng: Settings> Themes> General> Options> Theme hiệu ứng / Kích hoạt
Hỗ trợ Liên hệ: Nếu bạn tạo bản sao lưu với các bộ Ovi sẽ có vấn đề, do đó, quá trình làm theo để giữ cho tất cả các số điện thoại của bạn là:
Từ điện thoại của bạn vào sổ địa chỉ của bạn, chọn Tùy báo chí, nói rằng bạn cung cấp cho DIAL-> Chọn tất cả. Sau đó bấm Options một lần nữa và đưa vào kinh doanh CARD COPY -> Trong một báo cáo khác, chọn bộ nhớ bên ngoài của bạn và sẵn sàng.
Khi bạn đã có điện thoại Symbian của bạn với ^ CFW của chúng tôi 3 v6 cài đặt, do đó bạn chỉ cần vào sổ địa chỉ của bạn lần nữa bấm Options, sau đó kinh doanh CARD -> Trên bộ nhớ khác và chọn bộ nhớ bên ngoài của bạn. Phương pháp này không chỉ dễ dàng hơn và nhanh hơn nhưng nó cũng là nhiều hơn nữa hoàn thành bởi vì tất cả các hình ảnh được lưu liên lạc và tất cả mọi thứ được thực hiện từ điện thoại tương tự.
Kích hoạt tính năng quay: Cài đặt - Điện thoại - Conf cảm biến - điều khiển kích hoạt - Tự động xoay màn hình
Tem: Các tem bạn đặt vào bộ nhớ bên ngoài của bạn trong thư mục E: / Sounds / Digital
Tin cập nhật: Cập nhật được đã được xây dựng, xin vui lòng hiểu rằng không cần phải cài đặt lại chúng.
Âm thanh máy ảnh: Camera> Options> Settings> Capture âm> Camera 4
THÔNG BÁO CỦA CỘNG ĐỒNG LỖI
VẤN ĐỀ GIẢI PHÁP
Không có ánh sáng màu xanh lá cây trên Nokia 5530 Chúng tôi đang chờ xác nhận và nếu một lỗi được khắc phục, các gói tải về trong cả tuần. Theo báo cáo cũng giải quyết bằng cách chỉ thay đổi chủ đề ...
Trong La tinh 5800, không phải là một tùy chọn để đặt lại điện thoại Đó là một giám sát trên một phần của chúng tôi và mặc dù văn bản xuất hiện, nếu chức năng tích hợp nhưng cho chính xác hơn trong tuần.
liên kết
kái này và cfw c6 khác nhau chỗ nào nhỉ?pạn nào jaf r .gjảj thjx cho mình pít nha.
Đợi bạn vuducthanh mod xong mình sẽ làm chuột bạch luôn:D
#vuducthanh: Bao giờ có hàng hả bạn ơi?:) À, thêm nữa, mình đang xài x6 bạn àh :D
vuducthanh đã add TV và chạy thử từ hôm qua có nhận xét như sau:
- Bản này lang tiếng EN và TBN chạy khi jaf xong RAM khoảng 48M.
- add thêm TV lỗi rất nhiều thứ như: tin nhắn, ứng dụng, menu...
- không cook thêm bất cứ ứng dụng nào, chủ đề thêm mỗi Symbian^3 còn lại toàn chủ đề gốc của nokia.
- icon 4x4 gốc nokia
- HS của c6
- font chữ bé
- camera co 3M.
- tóm lại không có gì mới.
* Khuyên: AE đừng hy vọng vào bản này. Quá chán.
Mình cũng dùng X6.
Chẳng hiểu ai làm bản này mà lại dùng FW RM-559 31.0.004 v20 của VN để cook ngôn ngữ EN-TBN, chắc là mới tập cook vì vậy AE đừng flash cho t ốn công.
- HS của c6
- font chữ bé
- camera co 3M.
Mình cũng dùng X6.
Đang định jaf thấy thế này nản luôn,
trước xài 58 chạy bản v6 thấy ngon mà nhỉ
mình muốn chỉnh lại bàn phím số như bình thường của 5530 thì mod thế nào vậy
mình đang chạy bản này .58k nhá. Ram bình quân đc 38MB, ngôn ngữ EL. đang chạy thử vài ngày đã, xem có tốn pin ko đã, nếu đcc 2 ngày thì mình sẽ dùng bản này luôn :D camera 3M của 5800 nguyên bản, nên vậy ok rùi.
Dùng English ko thỳ cũng được, nhưng duyệt web bằng phone thỳ ko chat tiếng Việt được!
chán ghê.. vừa dow về để flash kon X6 mà nghe Thanh nói thế này lại chán rồi :)):))
