CFW Deviant-03 for 523x by Nguyễn Duy Thanh (21/07/2011)
Sau khi sử dụng firmware bạn cảm thấy thế nào?
  • Số thành viên bình chọn
    161
Trạng thái
Xóa Icon Shazam trong musicsuite cho ai cần này. Xin phép DT nhá :)
<?xml version="1.0" encoding="UTF-8"?>
<mm:content xmlns:mm="http://nokia.com/mmenu"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://nokia.com/mmenu ../mmenuschema.xsd" genre="musicsuite">
<mm:localization namespace="musicsuite_loc" source="musichomescreen.rsc"/>
<mm:item count="1" template="logical_template_6" id="msuitecps">
<mm:menuitem name="musicsuite_loc:R_MUSICHOMESCREEN_OPTIONS_OPEN" event="key:select" position="1" />
<mm:menuitem name="musicsuite_loc:R_MUSICHOMESCREEN_OPTIONS_HELP" event="custom:musicsuitehelp" position="2" />
<mm:query namespace="musicquery" service="Service.ContentPublishing" interface="IDataSource">
<mm:command mode="sync" name="GetList">
<mm:key name="type" type="string" value="cp_data"/>
<mm:key name="filter">
<mm:key name="publisher" type="string" value="MWPublisher"/>
<mm:key name="content_type" type="string" value="text"/>
<mm:key name="content_id" type="string" value="musicmenu_musicinfo_text1"/>
</mm:key>
</mm:command>
</mm:query>
<mm:notify_request service="Service.ContentPublishing" interface="IDataSource">
<mm:command name="RequestNotification">
</mm:key>
</mm:command>
</mm:notify_request>
<mm:output alias="mul_title" type="string" value="musicquery:results/[$index]/data_map/musicmenu_musicinfo_text1data"/>
<mm:query namespace="musicquery2" service="Service.ContentPublishing" interface="IDataSource">
<mm:key name="content_id" type="string" value="musicmenu_musicinfo_text2"/>
</mm:key>
</mm:command>
</mm:query>
</mm:key>
</mm:command>
<mm:output alias="mul_detail" type="string" value="musicquery2:results/[$index]/data_map/musicmenu_musicinfo_text2data"/>
<mm:query namespace="musicquery3" service="Service.ContentPublishing" interface="IDataSource">
<mm:key name="content_type" type="string" value="image"/>
<mm:key name="content_id" type="string" value="musicmenu_musicinfo_image"/>
</mm:key>
</mm:command>
</mm:query>
</mm:key>
</mm:command>
<mm:output alias="mul_icon">
<mm:image bitmap="musicquery3:results/[$index]/data_map/musicmenu_musicinfo_imagedata" mask="musicquery3:results/[$index]/data_map/musicmenu_musicinfo_imagedata_mask"/>
</mm:output>
<mm:event event="key:select">
<mm:action service="Service.ContentPublishing" interface="IContentPublishing">
<mm:command name="ExecuteAction">
<mm:key name="filter" type="map">
<mm:key name="action_trigger" type="string8" value="MMInfoTrigger"/>
</mm:key>
</mm:command>
</mm:action>
</mm:event>
</mm:item>
<mm:item count="1" template="logical_template_6" id="msuitemymusic">
<mm:output alias="mul_title">
<mm:text value="musicsuite_loc:R_MUSICHOMESCREEN_MY_MUSIC"/>
</mm:output>
<mm:key name="publisher" type="string" value="MpxCollectionPublisher"/>
<mm:key name="content_type" type="string" value="integer"/>
<mm:key name="content_id" type="string" value="musicmenu_collectioninfo_numb1"/>
</mm:key>
</mm:command>
</mm:query>
</mm:key>
</mm:command>
<!-- only one song present -->
<mm:output alias="mul_detail" condition="musicquery3:results/[$index]/data_map/musicmenu_collectioninfo_numb1data = 1">
<mm:text value ="musicsuite_loc:R_MUSICHOMESCREEN_MY_MUSIC_1_SONG"/>
</mm:output>
<!-- multiple songs present -->
<mm:output alias="mul_detail" condition="musicquery3:results/[$index]/data_map/musicmenu_collectioninfo_numb1data &gt; 1">
<!-- %N songs present -->
<mm:text value ="musicsuite_loc:R_MUSICHOMESCREEN_MY_MUSIC_N_SONGS">
<mm:param value="musicquery3:results/[$index]/data_map/musicmenu_collectioninfo_numb1data"/>
</mm:text>
</mm:output>
<!-- default - no songs present -->
<mm:output alias="mul_detail">
<mm:text value="musicsuite_loc:R_MUSICHOMESCREEN_MY_MUSIC_NO_SONGS"/>
</mm:output>
<mm:image application_uid="0x102072C3"/>
</mm:output>
<mm:action service="Service.ActionHandler" interface="IDataAction">
<mm:command name="Execute">
<mm:key name="plugin_id" type="uid" value="0x10207C16"/>
<mm:key name="data">
<mm:key name="type" type="string" value="MessageToMusicPlayer"/>
<mm:key name="message" type="string" value="GoToMusicLibrary"/>
<!--mm:key name="Path" type="string" value="MusicMenu"/-->
</mm:key>
</mm:command>
</mm:action>
</mm:event>
</mm:item>
<mm:item count="1" template="logical_template_6" id="msuitefmradio">
<mm:text value="musicsuite_loc:R_MUSICHOMESCREEN_FM_RADIO"/>
</mm:output>
<mm:text value="FM Radio trong tầm tay"/>
</mm:output>
<mm:image application_uid="0x10207A89"/>
</mm:output>
<mm:key>
<mm:key name="plugin_id" type="uid" value="0x10282E5F"/>
<!-- At least one sub element is required in the data key. -->
<mm:key name="type" type="string" value="launch_application"/>
<mm:key name="launch_method" type="string" value="cmd_line"/>
<mm:key name="application_uid" type="integer" value="0x10207A89"/>
</mm:key>
</mm:key>
</mm:command>
</mm:action>
</mm:event>
</mm:item>
<mm:text value="Music Stopper"/>
</mm:output>
<mm:text value="Hẹn giờ tắt nhạc"/>
</mm:output>
<mm:image application_uid="0x20036d13"/>
</mm:output>
<mm:key>
<mm:key name="application_uid" type="integer" value="0x20036d13"/>
</mm:key>
</mm:key>
</mm:command>
</mm:action>
</mm:event>
</mm:item>
</mm:content>
anh úp giúp em cái link của bãn binh24 nha. rồi sao nữa anh
Vào blog duybinh24.blogspot.com mà download firmware chưa mod (hoặc download bản 5800 của ai trên forum), bạn có thể khôi phục wifi bằng cách tìm các file sau và copy vào:
\sys\bin\WIFIPROTCLIENT.DLL
\sys\bin\WIFIPROTPLUGIN.DLL
\sys\bin\wlansettingsui.dll
\sys\bin\wlansniffer.exe
\sys\bin\wlanwapiif.dll
\sys\bin\WlanPkt.drv
\sys\bin\WlanMgmtImpl.dll
\sys\bin\wlanplugin.DLL
\sys\bin\wlanindicatorplugin.dll
\sys\bin\WlanPowerSaveImpl.dll
\sys\bin\wlaneapolif.dll
\sys\bin\WlanControlImpl.dll
\sys\bin\WlanDeviceSettings.dll
\sys\bin\wlanagthotspotimpl.dll
\private\10003a3f\apps\wlansniffer_reg.rsc
\Resource\apps\wlanplugin.mif
\Sys\Bin\wsfaihelper.exe
\Sys\Bin\wsfwlaninfosorting.dll
\Sys\Bin\wsfapwizard.dll
\Sys\Bin\wsfaiplugin.dll
\Sys\Bin\wsfmodel.dll
\Sys\Bin\wsfclient.dll
\Sys\Bin\wsfserver.exe
\Sys\Bin\wsfwlaninfo.dll
\private\10003a3f\apps\wsfaihelper_reg.rsc
\Resource\apps\wsficons.mif
\Resource\apps\wsficons_aif.mif
\Resource\apps\wsfwlaninfosorting.mif
\Sys\Bin\wlmplatform.dll
\Sys\Bin\WlmServerExe.exe
\Sys\Bin\WlmServerSrv.dll
\Sys\Bin\HotSpotServer.exe
\Sys\Bin\hotspotclient.dll
\Sys\Bin\ictsclientinterface.dll
\Sys\Bin\HsBrowser.exe
\private\10003a3f\apps\HsBrowser_reg.rsc
\Resource\apps\HsBrowser.r01
\private\10282EC5\backup_registration.xml
\Sys\Bin\NetCfgExtnHotSpot.dll
\Sys\Bin\HssMgmtImpl.dll
DT cho mình hỏi nếu muốn tách lấy swype to unlock của bản này thì cần tách những file nào được ko?
thanks
còn cái phím trượt hd thỳ sao anh
Muốn thay giao diện Swipe to unlock thì tìm file resource\apps\telgesturecontrols.mif của bản mà bạn ưng ý thay vào.
thanks
Tách lấy giao diện hay tất cả. Nếu là giao diện đọc phần trên.
thế fix đèn sao bạn. Mình rất thích lim dim.. Nếu k thêm mod gì thì đèn đỏ ság còn thêm bật đèn phím cứg thì đèn xanh tắt... Với thanh media bar ko vào đc trình xem ảnh...
Của bạn là 5530 nên mình ko rõ. Mod đèn cũng mình mod đã test làm việc tốt 523x, chẳng hiểu sao bỏ sang 5530 lại thế :(
P/S: Ngủ, mai giải đáp ae sau.
cho mình tất đi///
chứ mình lấy giao diện của bản này cho vào N97 mini thì không dùng được
Duy Thanh ơi, bạn cố gắng làm nốt bản x6 đi có đc ko, mình chờ fw của bạn mãi, cuối cùng lại ko thấy chán quá, bạn làm nốt cái x6 đi cho anh em dùng x6 đỡ buồn :((
Trạng thái
