CFW Vietnamese-05 (Nhanh-Mượt) for X6 /5530 /523x /5800 by ThanhTungHT (18/02/2012)
Trạng thái
cho em xin nốt cái focus trong camera đi các bác.để em fix 1thể flash luôn.hôm trước thử 1 mod thì bị lỗi font trong camera.
X6 hack xong ko mở được, bật nguồn thì dt rung 1 cái rồi thôi, màn hình tối om
đây là log:
JAF version 1.98.62
Detected PKEY: 90009B6C
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.69.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-559\
Searching for default location of ini...
Checking path: \Products\RM-559\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.rofs2.V20
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_32.0.002_001_000_U001.uda.fpsx
Detected P-KEY: 90009B6C
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 009.012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting................PUBKEYS already sent...
..........Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 1004, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.core.C00...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 0B71FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.rofs2.V20...
Erasing cmt zone 02EC0000 - 0B61FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_C01_prd.rofs3.fpsx...
Erasing cmt zone 0A300000 - 0B71FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_32.0.002_001_000_U001.uda.fpsx...
Erasing cmt zone 0B720000 - 1EF7FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Sending CMT HASH for SOS+ROFS3
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
MCUSW: V ICPR72_11w16.1
28-07-11
RM-559
(c) Nokia
APESW: V 40.0.002
VariantSW: V 40.0.002
Prodcode: 0589429
Setting test mode...
Setting FULL FACTORY...
Operation took 0 minutes 6 seconds...
Done!
Done!
Mong các bác chỉ cho e với
thêm mod này vào đi tùng:http://forum.dailymobile.se/index.php?topic=36643.0
Có cả mod menu 4x6 ah`? :D Nhìn thik thế? :))
đây là log:
JAF version 1.98.62
Rebooting...
Restarting CMT...
Pooling phone...
28-07-11
RM-559
(c) Nokia
APESW: V 40.0.002
Prodcode: 0589429
Done!
Done!
Hiện tại New Core X6 đang bị lỗi bạn nhé.Bạn thử Flash bằng 2 file.Hoặc Bạn down Core này về : X6 RM-559 V32 New Core by Binh24.7z + đổi tên Rofs2 của mình thành : RM-559_32.0.002_prd.rofs2.V20 để Flash.Hoặc bạn nào đấy đã Flash thành công X6 ở V40 có thể giúp bạn này nhé ;;)
Hoặc là bạn dùng KillMe giết PopupClock là Ok đấy bạn.
Mình dùng KillMe giết PopupClock xong giờ lại vướng nút gạt khoá bên hông cũng ko xài được Slide unlock ( bị mờ tối màn hình ko bấm được )
Dùng Nokia FW Cleaner 3.0 beta1 cũng ko xoá được dung lượng file vẫn như cũ , bản Nokia FW Cleaner 2.2 thì ko thấy mục Swype to unlock đâu để xoá
Hay là bác ThanhTung làm bản Non to Unlock cho nokia 5233 đi , thanks bác rất nhiều
bạn Tùng cho mình hỏi cách tách theme từ cfw với...mình muốn tách một số theme mà chưa biết cách..thank!
bạn tùng cho mình mod wiget đóng khung nhưg mình cok xong y chang như cũ gióng sym 3 mình thích giống n97 s60v5 hơn xem lai mình hộ cái đâu fai do thême fai ko bạn
Cái bản của 5800v60 sao Camera bị lỗi ký tự lạ ở 2 nút Thoát và Tùy Chọn vậy ??? Ai biết cách Fix chỉ mình với để mình làm luôn. Thanks
cho mình hỏi mới nha: mình muốn del cái apps killme.Thì mình bung ra rôi, vào rofs2\Sys\Bin có 2 file Killme.exekillmestarter.exe...thì có phải chỉ cần del 2 file đó xong flash là sẽ del đc app killme k?mọi người chỉ cho mình với..mình ghét app killme lắm ..Mình muốn xóa app kill me!.tks
tùng ơi trong camera còn bị lỗi font kìa! mình mới flash bản của tùng thôi! chưa mod thêm gì hết!
lỗi font EN hay Vi thì bạn tìm file cameraapp.r01 hoặc r96 từ bản k bị lỗi thay tương ứng là được
hoặc cứ seach lần lượt với 2 từ khóa "camera .r96" và "camera .r01" từ bản k lỗi và thay tương ứng. :P
cứ copy lại từ khóa trong " " của mình mà seach
Đợi tý mình Up cái Mod Fix Camera lên cho mấy bạn ;;) Tại dùng Mod Fix Camera Belle nên mới bị thế =)) Mà đôi lúc dùng thế thì máy mới độc :D
Xóa KillMe hã :D App KillMe : Click rồi xóa theo Mod nha.
sao mình dùng 5233 không thấy lỗi font chổ nào ta:(
ai pít cách flash 2 file bày mình với sao mình làm theo trong video khi kéo thả nó không đc:-/
5233 ngon mà e,a dùng 5233 mà :)) Cứ kéo thả đi khắc được,chú ý thả đúng nơi đúng chổ mới thành công =))
Mod Fix kí tự lạ trong Camera đã trên #1.
e keo thả miết mà cũng không đc luôn a, a cho e cái nick yahoo đc không để a hướng dẩn e qua team view đc không
Trạng thái
