Chương trình quản lý và Set Permission cho iPhone
Cám ơn bác,nhưng mà chỉ dùng được khi có wifi thôi,không có wifi thì chịu,thế mới khổ :-??
WinSCP 4.2.2 Beta (29/06/09)
WinSCP is freeware SCP (Secure Copy) client using SSH (Secure Shell). Its main purpose is safe copying files between local and remote computer. Beyond this basic function, it manages some other actions with files. It can do all basic operations with files, such as copying and moving. It also allows you to rename files and folders, create new folders, change properties of files and folders. One of two selectable program interfaces allows user to manage files even on local computer. Most operations can be done recursively for files in folders. WinSCP is also available as a plugin to two file managers, FAR and Servant Salamander.
Features:
• Graphical user interface
• Translated into several languages
• Integration with Windows (drag&drop, URL, shortcut icons)
• All common operations with files
• Support for SFTP and SCP protocols over SSH-1 and SSH-2
• Batch file scripting and command-line interface
• Directory synchronization in several semi or fully automatic ways
• Integrated text editor
• Support for SSH password, keyboard-interactive, public key and Kerberos (GSS) authentication
• Integrates with Pageant (PuTTY authentication agent) for full support of public key authentication
• Windows Explorer-like and Norton Commander-like interfaces.
• Optionally stores session information.
• Optionally supports standalone operation using a configuration file in place of registry entries, suitable for operation from removable media
Most important changes are:
* FTPS (FTP over TLS/SSL) support.
* It is possible to change group/owner of a remote file by UID/GID.
* XML logging for more formal and machine-readable representation of operations performed during the session.
* Filter for file panel.
Changes in version 4.2.2 Beta, 2009-06-28:
Homepage
Download WinSCP 4.2.2 Beta Portable Executable
Download WinSCP 4.2.2 Beta Installation Package
Download WinSCP 4.1.9 Portable Executable
Download WinSCP 4.1.9 Installation Package
All Downloads
có ai giúp mình với mỗi lần mình dùng ­­­­chuong trình mình điều bị báo lỗi là máy của mình mạng bị lỗi hoài huhuhuh khổ quá
-e xài Itunes 8.2
- đã cài Cài .NET Framework 3.5
- cài open ssh lun goài
- iphone version 2.2.1 custom cuối cùng của bác j trong điễn đàn lun !!!
mà báo là : Software caused connection abort !
- giúp e với :(( thanks
Cám ơn bác NguyenHuuTrong. Nói chung, bài như vậy là quá chuẩn, hướng dẫn kỹ cho anh em thực hiện.
Mình chỉ bổ sung 1 chút là nếu IP đã có BossPrefs thì có thể tạm thời set 0755 permissions có sẵn trong chương trình này trong khi chưa down được Winspc no wifi hoặc Iphone Tunnel Suite.
Ngoài ra, dù là bản IP Tunnel Suite 2.7 nhưng vẫn chưa có FW 2.1 hoặc 2.2, cứ nhấn vô 2.0.2 cũng vẫn chạy vô tư.
Cho e hỏi cái BossPrefs có sẵn trong máy hay phải cài vào vậy, nếu cài thì cài ở đâu, bác nào cho em xin link với.
E dùng 3G FW 2.2.1 không kết nối được bằng winspc Network error:
Software caused conection abort
. Helf me
Giúp em với ..
Cài cái ITS thì khi ko ghim cáp vài ip thì 2 cái ITunel và IConnect Status đều running ( màu xanh ) Còn khi ghim cáp vào IP thì chỉ còn Itunel running thôi còn thằng quỹ IConnect thì nó Stoped hoài .. làm sao để hiện lên cái bảng như đầu topic để chuyển file MobileInstallation vào như đường dẫn đc vậy ..
Còn cài Winspc_no_wifi thì sao mình làm theo hướng dẫn vào edit đánh thông số và pass là alpine vào khi bấm login thì nó báo error:
Software caused conection abort là sao vậy các bác .. hic .. còn có công việc chuyển cái file gì đó MobileIns vào System/Library/PrivateFrameworks/MobileInstallation.framework nữa mà ko làm đc để có thề cài app trên Itune mà ko làm đc đau lòng quá .. các bro chỉ dzùm .. acc Itune thì em reg rùi .. down file ipa vào quá trời mà Sync ko đc :( Giúp với ! :( Em xài máy nhà chứ ko phải laptop chắc ko có liên quan gì đâu phải ko ?
Giúp dzùm em với, còn 1 công đoạn cuối cùng nữa mà .. :(
bupbe đã cài Winspc no wifi thành công, bây giờ phải làm sao để chuyển những files prc từ desktop vào iphone xin mấy anh chị chỉ giùm. em cám ơn
Tham khảo bên khu vực KỸ THUẬT SỬ DỤNG nhé, có hướng dẫn hết rồi đó!
