E71 - v510 Công nghệ MiniCMD mới nhất H@CK VĨNH VIỄN ROM
nguyentanbinh
Well-Known Member
Cái này thì khỏi quảng cáo rồi theo công nghệ của E63 anhtamhcm nay áp dụng thay cho E71
ĐÂY LÀ ICON ỨNG DỤNG CHẠY ẨN
OVI MAP 3.04 COOK ROM
Note: All Run code MiniCMD 2.3
#Lệnh Sao lưu danh bạ
cp /o c:\private\10003a73\contacts.cdb e:\Backup\contacts.cdb
#Lệnh Xóa rác
delete c:\Private\10005A3E\mediaplayer.dat
delete c:\Private\101f6efa\reserve.bin
delete c:\private\101f7295\sidcache.cache
delete c:\private\101ffc31\glxmdstn
delete c:\private\102072c4\reserved
delete c:\private\20012FA6\library.db
delete c:\private\a000b868\smartmovie\filelist.ini
delete c:\private\a000b868\smartmovie\recent.txt
delete c:\*.txt
delete c:\data\hxmdengine_3_2.cfg
delete c:\data\*.txt
delete c:\data\others\PingCoLog\
delete c:\data\powlite_fm.mbm
delete c:\data\r1_mobile_4_0.cfg
delete c:\private\100012a5\dbs_101f8683_scshortcuengine.i ni
delete c:\private\100012a5\dbs_101f8878_template.n31
delete c:\private\100012a5\DBS_10207216_SWInstLog.db
delete c:\private\10005399\schedulesbackup.dat
delete c:\qqplugininfo.dat
delete c:\sys\install\sisregistry\backup.lst
delete c:\system\apps\applnst\appinst.ini
delete c:\system\data\cbs\cbtopicsmsgs.dat
delete c:\system\data\music.db
delete c:\system\data\QuickOffice\cache.txt
delete c:\system\date\applications.dat
delete c:\system\date\quickoffice\cache.txt
delete c:\system\date\tore
delete c:\system\install\install.log
delete c:\system\*.txt
delete c:\system\vid.dat
delete c:\tempva
delete c:\_palbtn
delete c:\data\*.css
rm c:\12530\mm\cache\
rm c:\cache\
rm c:\cookie\
rm c:\Cookies\
rm c:\Data\Baidu\BaiduHand\Cache\
rm c:\data\dxinfo_3gt\cache\
rm c:\data\HDesktop_0x2001E8B2\sisbackup\
rm c:\data\index\
rm c:\data\installs\
rm c:\Data\Juice\temp\
rm c:\Data\lifeblog\
rm c:\data\logs\
rm c:\Data\Mini\
rm c:\Data\NEF\
rm c:\data\netdragon\http\
rm c:\data\netdragon\httpcache\
rm c:\data\others\PingCoLog\
rm c:\data\smaper\history\
rm c:\data\sogou\sogou_net\
rm c:\data\sogou_net\
rm c:\data\Tencent\QQBrowser\temp\
rm c:\date\dxlnfo_3gt\cache\
rm c:\date\logs\
rm c:\go_s60\backup\
rm c:\go_s60\cache\
rm c:\go_s60\temp\
rm c:\gotmp\
rm c:\Juice\temp\
rm c:\logs\
rm c:\Others\ucbackup\
rm c:\Predic\
rm c:\private\10003a3f\temp\
rm c:\Private\101f6efa\
rm c:\private\101f8530\
rm c:\private\101f8857\cache\
rm c:\Private\101f96ec\
rm c:\private\101ffa91\
rm c:\Private\10202dce\
rm c:\private\10207218\
rm c:\private\1020735b\
rm c:\Private\200002c0\Catalog\
rm c:\Private\20001801\
rm c:\Private\20007801\
rm c:\private\2000cea3\cache\
rm c:\Private\2000EF45\RES\Browser\
rm c:\Private\2000EF45\RES\PingCoImage\
rm c:\Private\2001A492\cache\
rm c:\private\2001F848\WebImageCache\
rm c:\private\2001F848\WMLImageCache\
rm c:\private\200294B6\apps\Image\
rm c:\private\2002C577\WebImageCache\
rm c:\private\2002C577\WMLImageCache\
rm c:\Private\2003156A\RES\Browser\
rm c:\Private\2003156A\RES\PingCoImage\
rm c:\private\6dfae226\
rm c:\private\a0000bcf\messenger\history\
rm c:\private\A000998F\WebImageCache\
rm c:\private\A000998F\WMLImageCache\
rm c:\private\A000B868\SmartMovie\Thumbnails\
rm c:\Private\edbb5779\icon\
rm c:\Private\f101F848\SysImageCache\
rm c:\Private\f101F848\WebImageCache\
rm c:\Private\f101F848\WMLImageCache\
rm c:\qip\history\
rm c:\QQLog\
rm c:\QQMail\cache\
rm c:\Resco\Viewer\
rm c:\rescothumbs\
rm c:\Space\
rm c:\Space\cache\
rm c:\sys\install\integrityservices\
rm c:\Sys\install\temp\
rm c:\Sys\UnInstall\
rm c:\system\apps\aspbrowser\down\
rm c:\system\apps\bayanicq\history\
rm c:\system\apps\binpda\
rm c:\System\Apps\fetion_data\cache\
rm c:\System\Apps\fetion3\data\cache\
rm c:\system\apps\magickey\boot_ok\
rm c:\system\apps\mobileagent\history\
rm c:\system\apps\MQQAudio\
rm c:\System\Apps\MSN\Caches\
rm c:\system\Apps\phone\Totalrecall\Inbox\
rm c:\System\apps\QQBrowser\images\
rm c:\system\apps\qqgamehall\browser\history\
rm c:\system\apps\smaper\history\
rm c:\System\cache\
rm c:\system\data\ahle\
rm c:\System\Data\gobackup\
rm c:\system\data\opera\cache\
rm c:\system\data\opera\cache4\
rm c:\system\data\operamobile\cache\
rm c:\system\data\operamobile\cacheo\
rm c:\system\data\QuickOffice\cache\
rm c:\system\date\tore\
rm c:\System\dmgr\
rm c:\system\ipro7\history\
rm c:\system\smap\history\
rm c:\System\Smaper\history\
rm c:\System\temp\
rm c:\System\tmp\
rm c:\system\yreg\
rm c:\tempua\
rm c:\tmp\
rm c:\UCCACHE\
rm c:\uktemp\
rm c:\video_config\
delete e:\Private\10005A3E\mediaplayer.dat
delete e:\Private\101f6efa\reserve.bin
delete e:\private\101f7295\sidcache.cache
delete e:\private\101ffc31\glxmdstn
delete e:\private\102072c4\reserved
delete e:\private\20012FA6\library.db
delete e:\private\a000b868\smartmovie\filelist.ini
delete e:\private\a000b868\smartmovie\recent.txt
delete e:\data\hxmdengine_3_2.cfg
delete e:\data\others\PingCoLog\
delete e:\data\powlite_fm.mbm
delete e:\data\r1_mobile_4_0.cfg
delete e:\private\100012a5\dbs_101f8683_scshortcuengine.i ni
delete e:\private\100012a5\dbs_101f8878_template.n31
delete e:\private\100012a5\DBS_10207216_SWInstLog.db
delete e:\private\10005399\schedulesbackup.dat
delete e:\qqplugininfo.dat
delete e:\sys\install\sisregistry\backup.lst
delete e:\system\apps\applnst\appinst.ini
delete e:\system\data\cbs\cbtopicsmsgs.dat
delete e:\system\data\music.db
delete e:\system\data\QuickOffice\cache.txt
delete e:\system\date\applications.dat
delete e:\system\date\quickoffice\cache.txt
delete e:\system\date\tore
delete e:\system\install\install.log
delete e:\system\vid.dat
delete e:\tempva
delete e:\_palbtn
delete e:\data\*.css
rm e:\12530\mm\cache\
rm e:\cache\
rm e:\cookie\
rm e:\Cookies\
rm e:\Data\Baidu\BaiduHand\Cache\
rm e:\data\dxinfo_3gt\cache\
rm e:\data\HDesktop_0x2001E8B2\sisbackup\
rm e:\data\index\
rm e:\data\installs\
rm e:\Data\Juice\temp\
rm e:\Data\lifeblog\
rm e:\data\logs\
rm e:\Data\Mini\
rm e:\Data\NEF\
rm e:\data\netdragon\http\
rm e:\data\netdragon\httpcache\
rm e:\data\others\PingCoLog\
rm e:\data\smaper\history\
rm e:\data\sogou\sogou_net\
rm e:\data\sogou_net\
rm e:\data\Tencent\QQBrowser\temp\
rm e:\date\dxlnfo_3gt\cache\
rm e:\date\logs\
rm e:\go_s60\backup\
rm e:\go_s60\cache\
rm e:\go_s60\temp\
rm e:\gotmp\
rm e:\Juice\temp\
rm e:\logs\
rm e:\Others\ucbackup\
rm e:\Predic\
rm e:\private\10003a3f\temp\
rm e:\Private\101f6efa\
rm e:\private\101f8530\
rm e:\private\101f8857\cache\
rm e:\Private\101f96ec\
rm e:\private\101ffa91\
rm e:\Private\10202dce\
rm e:\private\10207218\
rm e:\private\1020735b\
rm e:\Private\200002c0\Catalog\
rm e:\Private\20001801\
rm e:\Private\20007801\
rm e:\private\2000cea3\cache\
rm e:\Private\2000EF45\RES\Browser\
rm e:\Private\2000EF45\RES\PingCoImage\
rm e:\Private\2001A492\cache\
rm e:\private\2001F848\WebImageCache\
rm e:\private\2001F848\WMLImageCache\
rm e:\private\200294B6\apps\Image\
rm e:\private\2002C577\WebImageCache\
rm e:\private\2002C577\WMLImageCache\
rm e:\Private\2003156A\RES\Browser\
rm e:\Private\2003156A\RES\PingCoImage\
rm e:\private\6dfae226\
rm e:\private\a0000bcf\messenger\history\
rm e:\private\A000998F\WebImageCache\
rm e:\private\A000998F\WMLImageCache\
rm e:\private\A000B868\SmartMovie\Thumbnails\
rm e:\Private\edbb5779\icon\
rm e:\Private\f101F848\SysImageCache\
rm e:\Private\f101F848\WebImageCache\
rm e:\Private\f101F848\WMLImageCache\
rm e:\qip\history\
rm e:\QQLog\
rm e:\QQMail\cache\
rm e:\Resco\Viewer\
rm e:\rescothumbs\
rm e:\Space\
rm e:\Space\cache\
rm e:\sys\install\integrityservices\
rm e:\Sys\install\temp\
rm e:\Sys\UnInstall\
rm e:\system\apps\aspbrowser\down\
rm e:\system\apps\bayanicq\history\
rm e:\system\apps\binpda\
rm e:\System\Apps\fetion_data\cache\
rm e:\System\Apps\fetion3\data\cache\
rm e:\system\apps\magickey\boot_ok\
rm e:\system\apps\mobileagent\history\
rm e:\system\apps\MQQAudio\
rm e:\System\Apps\MSN\Caches\
rm e:\system\Apps\phone\Totalrecall\Inbox\
rm e:\System\apps\QQBrowser\images\
rm e:\system\apps\qqgamehall\browser\history\
rm e:\system\apps\smaper\history\
rm e:\System\cache\
rm e:\system\data\ahle\
rm e:\System\Data\gobackup\
rm e:\system\data\opera\cache\
rm e:\system\data\opera\cache4\
rm e:\system\data\operamobile\cache\
rm e:\system\data\operamobile\cacheo\
rm e:\system\data\QuickOffice\cache\
rm e:\system\date\tore\
rm e:\System\dmgr\
rm e:\system\ipro7\history\
rm e:\system\smap\history\
rm e:\System\Smaper\history\
rm e:\System\temp\
rm e:\System\tmp\
rm e:\system\yreg\
rm e:\tempua\
rm e:\tmp\
rm e:\UCCACHE\
rm e:\uktemp\
rm e:\video_config\
#Kích hoạt sau khi Flash
abort_if_exists C:\System\data\RPPlus.dat
#Sao chép cấu hình sang ổ đĩa E
CP /o -r Z:\Copy-C\Micmd.txt e:\Backup\Micmd.txt
#Rompatcher ++
cp /o -r Z:\Copy-C\Rp\RPPlus.dat C:\System\data\RPPlus.dat
cp /o -r Z:\Copy-C\Rp\patches\Open4All.rmp C:\patches\Open4All.rmp
cp /o -r Z:\Copy-C\Rp\patches\c2z.rmp C:\patches\c2z.rmp
#AutoMacro Tự động sao chép sang ổ đĩa E
cp /o -r z:\Copy-C\Copy.ini e:\data\Copy.ini
#Bắt đầu bản vá Rompatcher
run 0RPAutoStart.exe
#Thời gian bắt đầu trễ sau 70 giây
sleep 70000
run FreeTimeBox.exe
Chi tiết Rom mod công nghệ MiniCMD 2.01
Video hướng dẫn chi tiết JAF của AnhtamHCM với E71 thì tương tự nhé chỉ khác tên 2 file thôi
[video=youtube;vPAElkN8aq0]http://www.youtube.com/watch?v=vPAElkN8aq0[/video]
Video dạng mp4 http://www.mediafire.com/?a3izzdbzy9v4jz4
Video dạng EXE xem trên PC http://www.mediafire.com/?ajgvkrb9aisav3x
CHI TIẾT ROM
I- Các mod khác
  1. 1-Theme effect. (8 Theme) [(Xóa 8 theme Effect) để tiện test trên C:]
    1. 1-Bống Tuyết
    2. 2-Hỗn Hợp
    3. 3-Sớm chớp mưa rơi
    4. 4-Sao lấp lánh
    5. 5-Sao siêu nhanh
    6. 6-Chim Phượng hoàng
    7. 7-Bống Ma
    8. 8-Lấp lánh trái tim
  2. 2-Mod Flash Ko mất {Danh bạ và Tin nhắn,Phím tắt ứng dụng màn hình chủ}.
  3. * Lưu ý : Trước khi Flash vào {C:\private\100012a5\} chép các File này vào
  4. E:\Backup\{DBS_100065FF_Contacts.cdb; DBS_101F8683_ScShortcutEngine.ini; 1000484b}.
  5. 3-Hack vĩnh viễn installserver.exe vào Z.
  6. 4-Mod các Patch {Beep call off, Đặt tên ở mạng, Tăng tốc CPU 1000MHz, Menu nâng cao}.
  7. 5-Mod 24 kiểu Menu.
  8. 6-Tối ưu hệ thống CPU 800 - 1000MHZ
  9. 7-Mod màn hình - nhạc khởi động Windows 7
  10. 8-Tối ưu quét nhạc chuông và hình tại Profile
  11. + C:\Data\
  12. + E:\Sounds\Digital\
  13. + E:\Videos\
  14. + E:\System\
  15. + E:\Images\
  16. 9-Quét các bài nhạc tại
  17. + E:\Music\
  18. 10-Bộ nhớ đệm trên E
  19. 11-Tự xóa các thư mục trên thẻ nhớ sau khi Flash hoặc Format
    1. rm e:\cache\
    2. rm e:\downloads\
    3. rm e:\Documents\
    4. rm e:\python\
    5. rm e:\Data\
    6. rm e:\Patches\
    7. rm e:\RDomain\
    8. rm e:\resource\
    9. rm e:\private\
    10. rm e:\system\
    11. rm e:\sys\
  20. 12- Mod tự download tiếp tục khi khởi động lại máy. [Mới Thêm]
  21. 13- Mod tin nhắn lưu 100.000 [Mới Thêm]
  22. 14- Mod log lưu 999 [Mới Thêm]
II- App cook Rom
  1. 1-RompatchPlus 2.3 Apply Auto. [delete]
  2. 2-JbakTasman 1.37 mod sac pin. [delete]
  3. 3-Memcheck v0.05.
  4. 4-Mod FontRounter. chép Font {*.ttf} bạn thích vào E:\data\Fonts\.
  5. 5-Mod Lịch vạn Niên 1.5 Full.
  6. 6-VietMap S17v1.06.0515 Full [delete]
  7. 7-RescoPhotoViewerv6.0
  8. 8-MiniCMD 2.01 (không có icon)
III-Xóa 8 theme mặc định của máy
IV-Các File sis thêm vào có thể update MiniCMD
  1. Applocker.sis (Khoa ung dung mo rong)
  2. Blacklist.sis (Chan cuoc goi)
  3. FileBrown.sis (Chep file he thong)
  4. GifTailor.sis (Quay Phim màn hình)
  5. Gtranslator.sis (Dich van ban online)
  6. MobilHex2.sis (Viet hoa phan mem)
  7. SmartMovie.sis (Phan mem xem phim)
  8. SmartSettings.sis (khoa phiem mo rong)
  9. Xplore157.sis (Quan li File)
  10. Xstal.sis (Go bo ung dung)
  11. TotalRecallv502.sis (Phần mềm ghi âm gọi)
  12. RPDomainPlusv2.03.sis (Mở hệ thống Phone)
  13. Photobook 2.25.sis (Phần mềm xem hình)
  14. JbakTaskMan141.sis (Quản lý File hệ thống pro) [Mới Thêm]
  15. Mobilhex150.sis (Việt hóa và unpack EXE-Dll) [Mới Thêm]
  16. PowerPython4All.sis (Hổ trợ Run các ứng dụng python) [Mới Thêm]
  17. sieudich206.sis (Việt hóa RSC - Py - Pyc) [Mới Thêm]
  18. BTReceiver.sis (Nhận file qua Blutooth không vào Inbox) [Mới Thêm]
  19. RomPatchv31.sis (Quản lý hệ thống) [Mới Thêm]
  20. EffectsE71.sis (Quản lý mục Effects) [Mới Thêm]
Đây là lệnh MiniCMD2
rm e:\cache\
rm e:\downloads\
rm e:\Documents\
rm e:\python\
rm e:\Data\
rm e:\Patches\
rm e:\RDomain\
rm e:\resource\
rm e:\private\
rm e:\system\
rm e:\sys\
Install -c z:\data\sis\Applocker.sis
Install -c z:\data\sis\Blacklist.sis
Install -c z:\data\sis\FileBrown.sis
Install -c z:\data\sis\Gtranslator.sis
Install -c z:\data\sis\MobilHex2.sis
Install -c z:\data\sis\SmartMovie.sis
Install -c z:\data\sis\SmartSettings.sis
Install -c z:\data\sis\Xplore157.sis
Install -c z:\data\sis\Xstal.sis
Install -c z:\data\sis\GifTailor.sis
Install -c z:\data\sis\TotalRecallv502.sis
Install -c z:\data\sis\RPDomainPlusv2.03.sis
Install -c z:\data\sis\PTB2.25.sis
Install -c z:\data\sis\JbakTaskMan141.sis
Install -c z:\data\sis\Mobilhex150.sis
Install -c z:\data\sis\PowerPython4All.sis
Install -c z:\data\sis\sieudich206.sis
Install -c z:\data\sis\BTReceiver.sis
Install -c z:\data\sis\RomPatchv31.sis
Install -c z:\data\sis\EffectsE71.sis
MD E:\Patches\
MD E:\RDomain\
MD E:\Data\Fonts\
CP Z:\Data\Patches\* E:\Patches\
CP Z:\Data\RDomain\* E:\RDomain\
CP Z:\data\Fonts\* E:\data\Fonts\
delete c:\data\MiniCmd.txt
sleep 70000
cp -r z:\system\universal\M1.txt c:\data\MiniCmd.txt
Note -c Nhấn-OK-để.khởi.động.và.sử.dụng.điện.thoại.của.bạn ĐÃ.CÀI.ỨNG.DỤNG.XONG !!!!!
Kill Phone.exe[/LIST]
Đây là link download 2 file (V29 và C00) này về mà Flash nhé các member
1/File V29 Đã cook thêm
  1. sieudich206
  2. PowerPython4All
  3. Mobilhex150
  4. JbakTaskMan141
  5. BTReceiver
  6. Mod Icon ứng dụng chạy ẩn là sonyerision
  7. RomPatchv3.1
  8. Effects
  9. Download tiếp tục khi khởi động lại máy
  10. Tin nhắn lưu 100.000-Log lưu 999
  11. Mod tắt sms java khi chơi các loại ứng dụng Java
    * Chúng ta đang sống trong thời đại kè xấu lợi dụng Java với các nội dung cuốn hút để lừa đảo nạp tiền vào tài khoản của họ. Nên Mình MOD thêm "Tắt tự động gửi SMS của Java". Để ae tránh mất tiền vì những Java lừa đảo đó.
    - Vì sao phải Tắt tự động gửi SMS của Java. Bởi vì nếu chẳng may mở cái Java lừa đảo nạp tiền vào các đầu số 87xx; 86xx; ... Các bạn sẽ mất khoản kha khá đó. Nhưng với MOD này thì chúng ta yên tâm không lo mất tiền nữa. Nếu có kích vào cái Java lừa nạp tiền thì sẽ hiện bảng thông báo có cho phép gửi tin nhắn đến (Tài khoản abcxx, đầu số 87xx không)? Và Bạn hãy chọn không để hủy tránh mất tiền.
1/File V29 Đã cook công nghệ xoay màn hình (Dead máy Wisi.ini)đang thử nghiệm
1/File V29 Đã cook của jundo_9x97
2/ File C00
File V29 Chưa Cook cái này cho những ai không thích FW cook mà muốn H@ck vĩnh Viễn
Chú ý :
- Khi Flash xong để máy khởi động đúng 70.000 giây tức là 1 phút 1 giây hiện chữ
Nhấn Ok để khởi động và sử dụng điện thoại của bạn
3-Hướng dẫn chỉnh file ini của Font
ZoomRatio=95 {độ lớn của font}
ZoomMinSize=20 {độ nét của chữ}
ZoomMaxSize=70 {độ đậm của chữ}​
Cài này có cải thiện gì k bạn... Hiện máy mình đã hack phone bình thường k phải vĩnh viễn... Với ít vọc k biết có nên up qua cái này k:|
A Tân Bình có thể chỉ e biết cách cook FP1 k ạ? Sử dụng công cụ gì để cook vậy a? Cook nó có giống như V5 k a?
E cảm ơn a!
