Flash Recovery - Rom Stock Rooted Cho Nook Color Tablet 16GB !
Taki7610
Unlock_GSM
1/ Trở về ROM stock cho NookColor :
Mã:
[COLOR="#FF0000"]C.1 [/COLOR]/ With the NOOKcolor powered off hold down the n button (home) and Power Button until the NOOKcolor powers on.
Tip: It may be best to hold both keys for a few seconds and release them just before the Welcome to the future of reading message disappears.
You will be prompted with a Factory Reset dialog.
Press POWER key to Exit
Press HOME key to continue
Press n button (home).
You will be prompted to confirm.
A Clearing Data dialog will show. NOOKcolor will reboot automatically once complete.--------
[COLOR="#FF0000"]C.2 /[/COLOR]Setting > Device Info > Erase & Deregister Device > Nhấp vào nút Erase & Deregister Device > Reset Nook
2/ CWN Recovery
1. Thẻ sd 8GB - File root NT16or8gbV4_6 image file.img .
Cách cài Root v2 CWN :
- Image file chọn file NT16or8gbV4_6 image file.img - Device chọn thẻ sd (không gắn các usb khác vào ) chọn Write quá trình sẽ tạo 1 sd card để root và vào CWM .
2 / File NT_stock_1.4.2_Ribbon_Root_B&N.zip ( Rom stock bao gồm root và có Market ).
Installation:
Mã:
1. Download the file: NT_stock_1.4.0_Ribbon_Root_v2.zip
2. Plug your Nook Tablet to your PC and check that Internal SDcard (MyNOOK) AND SDcard are mounted
3. Copy NT_stock_1.4.0_Ribbon_Root_v2.zip in the root (/) of Internal OR External SDcard (Pick one)
4. Eject safely your Nook Tablet
5. Boot into CWM
5.1 Wipe data then go to advanced>> wipe dalvik cache, once done press power button to go back
5.2 Go to Install zip from sdcard >> choose zip from sdcard (if you copied the folder to your External sdcard) >> select NT_stock_1.4.0_Ribbon_Root_v2.zip
5.2 Go to Install zip from sdcard >> choose zip from internal sdcard (if you copied the folder to your Internal sdcard [MyNOOK]) >> select NT_stock_1.4.0_Ribbon_Root_v2.zip
7. The process will start, once done Reboot your device ENJOY!
P/s : - Khắc phục thẻ sd card chỉ còn 64mb các bạn sử dụng SD Formatter để phục hồi lại nguyên trạng.
- Bỏ qua phần đăng kí nhanh gọn của Nook Color :
Giữ nút volume + bấm vào góc trái xong bấm góc phải màn hình.Lúc này sẽ hiện lên chữ factory.Thả nút volume + ra, bấm vào chữ factory.Giữ nút volume + bấm vào góc phải để hiện lên nút skip OBE , Bấm vào nút skip này là xong
-- Goodcluk !
