HƯỚNG DẪN: S-OFF, RECOVERY & ROOT CHO HTC EVO 3D (GSM)
em xin mạn phép các Pác em đọc và đã làm theo hướng dẫn, em là dân ngoại đạo nên thật khó hiểu và mày mò mãi mới làm được nên em xin phép up file word các bước: UNLOCK BOOTLOADER BẰNG HTCDEV
1. Step 11
You will receive an email with the attachment: Unlock_code.bin. Save this file in the same folder as your fastboot files (For Example: C:\Android).
If, after a short period of time, you have not yet received the mail, or you have received an email from HTC, but does not contain an attached file, it is possible that more stringent spam filters and anti-virus programs will block this mail or attachment.
In order to ensure that you receive the email with the attachment, we suggest you consider using a non-corporate email server as corporate servers tend to have more stringent attachment policies. If you have not received the email at all, please check your spam folder in your email client to check if the email was filtered out.
2. Step 12
In the command prompt type: fastboot flash unlocktoken Unlock_code.bin. In the command prompt you will see the following message:
3.
Step 13
On your phone you will now see the disclaimer. Please read this carefully as this action may void your warranty. Use the Volume buttons to highlight your choice, and the Power button to make your selection. If you select Yes, your phone will be reset to its’ factory default settings, and your bootloader will be unlocked. If you select No, your phone will reboot and no modifications will have been made.
4. Step 14
To re-lock your bootloader, in the command prompt, type: fastboot oem lock.
Note: This will not restore the factory default lock, but will simply re-lock the bootloader so no further changes can be made. Furthermore, if you want to unlock your bootloader again, simply repeat step 12 with your original unlock key file to unlock your phone again.
5. You're Ready To Go!
Congratulations! You have successfully unlocked your bootloader. Browse this site for further sample codes, examples, and tips.
o Take me to the Developer Center
o Additional Resources
Chúc các bạn nào gà mờ giống mình unlock thành công.
chỉ cần đến 12 là xong rùi.bạn copy nguyên xang đây làm gì cho loãng chur đề.nếu đã viết thì dịch xang tiếng việt đi cho anh em nhờ.còn như này thì trên trang web đó có hướng dẫn rùi mà.:(
HTC evo 3d không s-off được cần giúp đỡ
Máy của mình có imei: 356871040443040 sau khi lên trang web điền các thông số nhận được key WShr1X6lKysCKNX5 nhưng khi điền key vào phần mềm revolutionary-0.4pre4 để chạy thì toàn báo key không đúng không biết làm sai động tác nào nhờ anh em trên diễn đàn chỉ bảo giúp. thanks.
bạn dùng IMEI thì không lấy được key bạn nhé. nhập S/N vào. serial number đó. (có ghi trên vỏ hộp hoặc phía dưới cục pin đó bạn)
Ngoài ra bạn phải kiểm tra Hboot của bạn là bao nhiêu? Nếu là 0011 hoặc 0012 thì không dùng tool Revolutionary để S-Off được đâu nhé.
mình làm được rùi cám ơn tất cả anh em. tìm mãi chưa thấy bản rom cook cho nó anh em nào có cho mình xin mới. thanks
giup minh voi. minh da lam toi buoc 12 roi nhung trong man hinh cm: bao len nhu vay:
update <filename> reflash device from update.zip
flashall flash boot + recovery + system
flash <partition> [ <filename> ] write a file to a flash partitio
erase <partition> erase a flash partition
getvar <variable> display a bootloader variable
boot <kernel> [ <ramdisk> ] download and boot kernel
flash:raw boot <kernel> [ <ramdisk> ] create bootimage and flash it
devices list all connected devices
reboot reboot device normally
reboot-bootloader reboot device into bootloader
tions:
-w erase userdata and cache
-s <serial number> specify device serial number
-p <product> specify product name
-c <cmdline> override kernel commandline
-i <vendor id> specify a custom USB vendor id
Lỗi câu lệnh sai cú pháp nên nó hiển thị hướng dẫn cú pháp cho bạn.
Kiểm tra lại mọi thứ khi gõ, nếu thực hiện bằng tay hoặc nếu chạy file batch thì kiểm tra câu lệnh bên trong.
Chúc thành công.
minh da go cm: dung nhu huong dan o buoc 12. nhung cm: van bao nhu vay. vay trong cm: o buoc 12 minh phai go lam sao? giup minh voi
mở hộp mail ra có cái code do HTC gửi về copy vào thu mục android trên desktop!sau đó chạy tiếp dòng lệnh:fastboot flash unlocktoken Unlock_code.bin
goodluck;;)
máy của e HBoot 0011, e đã unlock xong tới bước cài recovery thì không dc nó hiện lên hình này
Các bác giúp e với
ko hiểu sao em cứ làm đến bước 5, lúc đánh xong dòng fastboot oem get_indentifier_token là nó lại báo [err] command error! ....hichic....hboot của em là 1.49.0011 Ai giúp với đc ko ạ
Gửi các bác, em cũng bị tình trạng này, mặc dù đã cài Driver, Htc Sync, và đã sync máy kết nối đầy đủ, cũng đã down đầy đủ tool theo yêu cầu của Hctdev. Nhưng vẫn bị tình trạng này, em đã làm các cách chỉ còn nước cài lại win, PC đang dùng Win 7 64 bit, Hboot 12, các bác cho lời khuyên nhé.
Cái này chắc sai đường dẫn. Nếu bạn dùng tool của chú Quang thì bạn sữa thư mục là Andoird và bỏ vào ổ C. Khi bạn chạy Unlock_Bootloader_EVO.bat thì trên màn hình dos C:\Android mới chạy được.
Nó đã báo OKEY rồi bạn còn đòi gì nữa:-?:D
Hôm qua e đã làm tới bước đó, nghĩ là thành công rồi. Khi vào fastboot chọn recovery thì khởi động lại không vào dc recovery. Hôm nay lại làm y chan vậy và bây giờ đã vào dc rồi. cám ơn mọi người;;)
Máy em Hboot 0011, đã Unlocked , Recovery, Root. nhưng sao nó vẫn báo S-On nhỉ các bác.
Đúng rồi đó bác, ko chịu đọc kĩ gì hết, Hboot 0011....0012 chưa S-Off được nhưng vẫn có thể up rom. Khi up nếu bi lỗi wifi thì có cách fix đấy.
Các bác cho hỏi. Máy của em vừa mua là EVO 3D phiên bản châu Á Hboot 0011. Em đã unlockbootloader, nhưng vẫn đang là S-on. Vậy là không dùng được revolutionary vì trong đó chỉ cho chon 2 version HBoot là 07 và 08. Vậy làm thế nào để S-OFF đây ạ. Mong các bác chỉ giáo
