TỔNG HỢP NHỮNG PHẦN MỀM FREE CHO PPC (PHẦN 2)
Opera Mobile 10 beta 3 for Windows Mobile phones (13/02/2010)
Requirements:WM6/WM6.1/WM6.5
Overview: Fulfilling vision of providing the best Internet experience on any device, Opera Mobile gives you a fast and full Web experience for smartphones.
Intuitive interface
Merging the best from our desktop browser with new innovations for phones, Opera Mobile is advanced and intuitive to use.
Faster browsing
Opera Mobile 10 beta is faster at rendering pages, zooming, panning and almost everything else you do with a browser. And pages load up to 50% faster than the previous version.
Speed Dial
Get to your favorite Web page with just one click, with a set of visual bookmarks that appear when you open a new tab. To add a new page, simply click on an empty Speed Dial slot.
Tabbed browsing
Browse several Web sites at the same time. Check your email in one window, Facebook in another, and Twitter in a third, all while easily jumping from one tab to another.
Main improvements from the previous betas:
* Opera Link
* Download manager
* UI is more finger-friendly on touch devices
* Possible to manage search engines
* Opera remembers page position and zoom state when moving in history
* Column snapping also on touch
* Better memory management
* Fix for mobile view crash
* Start page available from touch menu
* Lots of minor bug fixes
* Clear cache setting
* Asks whether to set Opera as default browser on install
* Fix for crash on startup (occurred on some devices due to encoding in bookmarks that were imported)
* Shortcut support.
Devices tested:
Acer N311, HTC Touch 2, HTC Touch Pro 2 (Rhodium), HTC Touch Diamond 2, HTC Touch HD, HTC Pure, HTC Touch Diamond, HTC Touch Pro, HTC Touch Viva, HTC Touch 3G, HTC Touch, HTC Tilt 2, HTC Touch Cruise, HTC Touch Cruise 2 (Iolite), HTC TyTn II, HTC TyTn, HTC Touch Pro (Raphael), Motorola Attila (A3100), Oki C4, Samsung Omnia i900, Samsung Omina II, Samsung SWD-M100, Sony Ericsson Xperia X1, Toshiba Portege, Toshiba TG01, Xda Zest
Download:
htcAddicts - cleanRAM v1.9.4 (14/02/2010) Mùn 1 tết Canh dần!
Mùn 1 tết Canh dần!
VH_htcAddicts - cleanRAM v1.9.4 tiếp tục cập nhật!
Phần mền dọn Ram hổ trợ tốt WM 5, 6, 6.1, 6.5![/B]
Mã:
changelog:
1. New backup settings for HTC HD2 best performance, you can load the recommended setting through cleanRAM Config -> "Backup / Restore" -> Select Settings: "HD2" or "HD2 Quiet".
2. New language strings.
3. New cleanRAM icons added (thanks to dinik).
4. Fixed bugs reported by the users community.
Thank Mod PhongQuang hổ trợ Việt hóa!!
VolumeKeys 0.4.1 - Volume Control (15/01/2010)
Hổ trợ (W)(Q)VGA ( VGA, WVGA, QVGA và WQVGA), Cài vào Main (Bộ nhớ chính)
Mã:
Changelog:
0.4.1 / 2010-01-15
- fixed display bug in (W)QVGA
- added landscape support
- fixed bug: volume not saved when slide outside the bar
- hopefully does not block keys
- added update check
- sound profiles (normal, mute, vibrate) are set
- added option to don't show anything on key press
- added AppToDate support
- added configurable position (left, right, top, bottom)
Download:
SetupInstallExpress1.5.3
SetupInstallExpress1.5.3 Cập nhật (02/2010)!! Chương trình tự động cài đặt ứng dụng, có thiết lập sau khi Up Rom, hay HR PPC.
BattClock 1.8.1 with *NEW* CPU% (19/02/2010)
Chương trình hiển thị đồng hồ số và ngày, dung lượng Ram, có thể thay đổi vị trí, màu sắc hiện thị, và nhiều tùy chọn khác...!
Mã:
19-2-2010 Version 1.8.1
Fixed update problems people reported
Reset the CPU counters at wake up from a deep sleep so the CPU% is more accurate
New BattClock icons, thanks to jaguaralani
Added current CPU to registry key HKCU\Software\ZuinigeRijder\Status\CPU, request from howdykeith, so you can e.g. add mortscript actions to it.
Added current FreeMemory to registry key HKCU\Software\ZuinigeRijder\Status\FreeMemory, so you can e.g. add mortscript actions to it when memory becomes low
Added current Battery % to registry key HKCU\Software\ZuinigeRijder\Status\Battery, so you can e.g. add mortscript actions to it when battery becomes low
cleanRAM v1.9.5​
Phiên bản cập nhật ngày 20/2/2010.
Xem thêm và tải tại trang chủ:
Mã:
http://www.htcaddicts.com/?id=110
WIFI Remote Access V1.6 beta 1
WIFI Remote Access V1.6 beta 1 cập nhật.
Ứng dụng này sẽ cho phép bạn khám phá những nội dung của PPC trực tiếp từ máy tính của bạn thông qua một kết nối WiFi mà không cần cài đặt bất kỳ phần mềm máy khác trên máy tính.Tất cả bạn cần là để mở trình duyệt web trên PC và gõ địa chỉ IP của PPC của bạn (được hiển thị trên màn hình PPC của bạn).Sau đó, bạn sẽ có thể duyệt dữ liệu, hình ảnh, và âm nhạc và gửi tập tin từ máy tính của bạn vào điện thoại. Bạn có thể xem hình ảnh và nghe nhạc trên máy tính của bạn trực tiếp từ giao diện web.
Hỗ trợ:
WM6 trở lên
[DOWNLOAD]http://jmanici.blob.core.windows.net/download/WIFI_Remote_Access_1.6_Beta1.zip[/DOWNLOAD]​
BattClock 1.9 with *NEW* CPU% (23/02/2010)
Mã:
 [B]23-2-2010 Version 1.9[/B]
Possibly to show the info in columns instead of rows (option Divide Horizontally)
Added option to show Battery Temperature (updated once per minute)
Added option to show Battery Current in mA (updated once per second), great to see power consumption
Show CPU also if it getidletime is greater than 100
WMM Notes v0.51
WMM Notes v0.51
Phần mềm viết ghi chú dạng *.txt hổ trợ các HĐH WM5, 6.0, 6.1, 6.5.xx!
Cập nhật ArkSwitch v1.1.0 [23-02-2010]
Cập nhật ArkSwitch v1.1.0 [23-02-2010] Quản lý tương tự task manager!
Chức năng quản lý, giải phóng các ứng dụng, giúp tiết kiệm RAM tương thích WM6.5xx, hổ trợ các màn hình
Manila 2D TodayPage v0.31
Manila 2D TodayPage v0.31 là chưong trình thêm các nút chức năng ở màn hình Today Manila 2D.
Hổ trợ các Manila 2D
2.0.1919.1432
2.0.1917.1723
1.2.1913.1530 (update 23)
1.0.1911.1733 (update 22)
1.0.1820.3328 (update 20)
1.0.1820.3327
1.0.1820.1830
1.0.1820.1233 (update 21)
1.0.1819.2926 (update 19)
1.0.1818.3719 (update 14-18)
Và .Net 2.0 trở lên!
Cập nhật ArkSwitch v1.1.1 [25-02-2010]
Cập nhật ArkSwitch v1.1.1 [25-02-2010] Quản lý tương tự task manager!
cleanRAM v1.9.6​
Phiên bản cập nhật ngày 26/2/2010.
Mã:
Cập nhật ClearTemp v1.3 (01/03/2010)
ClearTemp là một PM giúp giải phóng bộ nhớ, dọn dẹp các file và shortcurt thừa, xóa các key thừa trong registry,...
Hỗ trợ WM2003 trở lên và các loại màn hình...
Version 1.3 (28th February 2010)
Fixed dead shortcut detection & cleaning.
Fixed cach detection for Opera Mobile 10.
Added links to website & contact form.
Added back close button (X-button).
Added detection of thumbs.db and desktop.ini files on Storage Card.
Changed application icon.
Grouped higher risk items to the new advanced section.
DOWNLOAD ClearTemp v1.3
htcAddicts_cleanRAM_v1.9.8.0 & v1.9.8.1& v1.9.8.2_BETA
VH_htcAddicts - cleanRAM v1.9.8.xx tiếp tục cập nhật!
Mã:
Changelog (1.9.8.2):
Clear recent start menu items setting fixed
Stable Version
Changelog (1.9.8.1):
Remove language strings:
HD2 = HTC Sense
HD2Quiet = HTC Sense (Quiet)
Add language strings:
Manila1 = TouchFLO 3D
Manila1Quiet = TouchFLO 3D (Quiet)
Manila2 = HTC Sense
Manila2Quiet = HTC Sense (Quiet)
WM65GUI = WM6.5 GUI
WM65GUIQuiet = WM6.5 GUI (Quiet)
SPBShell = SPB Shell
SPBShellQuiet = SPB Shell (Quiet)
DefaultProfile11 = Best performance with TouchFLO 3D GUI
DefaultProfile12 = Best performance with TouchFLO 3D GUI - Quiet Mode
DefaultProfile13 = Best performance with Windows Default GUI
DefaultProfile14 = Best performance with Windows Default GUI - Quiet Mode
DefaultProfile15 = Best performance with SPB Shell GUI
DefaultProfile16 = Best performance with SPB Shell GUI - Quiet Mode
Default settings is now comes without "Close All Applications" setting.
cleanRAM is now support GUI cleaning, tested on: TouchFLO3D, HTC Sense,SPB Shell, Windows Mobile 6.5 Default GUI
Changelog (1.9.8):
Remove registry key: "htcSenseEnabled" (no need it anymore).
New registry key: "winGUI" added.
cleanRAM is now supports GUI cleaning, you can turn on the GUI mode by typing your WM GUI name to "winGUI" registry key value. For examples: winGUI = "HTC Sense" or winGUI = "TouchFLO 3D" etc. (note that, default value key for winGUI is "" = inactive clearing GUI).
Performance & Code Improved
More information will come later...
ToDo List:
1. Fix status screen (minor bug).
2. Change some strings on "Backup / Restore" feature.
3. Change the PDF Manual to the latest version.
Thanks anhphe76, bữa giờ tìm mãi mới được bản này chạy tốt trên HTC HD2 với ROM phiên bản mới.
htcAddicts_cleanRAM_v1.9.8.3_BETA (04/03/2010)
htcAddicts_cleanRAM_v1.9.8.3_BETA (04/03/2010) Test!
Mã:
Changelog (1.9.8.3):
The following strings are not translated: "WM65GUI", "WM65GUIQuiet", "SPBShell", "SPBShellQuiet"
