TOUCH WM6.1 ROM V46 - Build 20270.1.3.1 (ELF & ELFin)
The speed dial is not working!!!!!
I can set-up the speed dial number, but i can not access them.
I click on the green buttom then silver buttom ànd nothing..... with the original version that way was working
any ideas?
thanks
hi
Thx PhamQuang for this great ROM... there is one problem though, I can't manage to play mp3s.. WMP just pauses itself for no reason, and the audio manager does not work properly either... it lags and stops from time to time then starts again...
I noticed this issue in v44 too
is there a fix for this?
thx
me too!
the audio manager always pauses itself.
since v42\v44\v45\v46 has such problem.
hello friends, I dơnloaded v46 above and it went vẻy OK; the radio senisitivity í still verry loow. I noted that affter v46, my radio is 2.3.90 íntead ôf 3.12.90 and the protocol í not the same... I have a Touch, normal not extended
thanks ; correctable?? Hẻni
tôi tải bản ROM 2.20.707.44 về up lên xong giờ ko sài dc gprs
kết nối được nhưng không vào được mạng.
mong bác QUANG chỉ giáo.
XON CẢM ƠI.
Bác Quang ơi, sao các bản 44,45,46 con up lên rồi mà vẫn không có cái nào kết nối internet thông wa sync được hết ah Bác Quang
