[B]8-5-2010 Version 2.1 *NEW* 4 stripes[/B]
# Fixed bug that Battery charge indicator was not shown when also other Battery items were shown
# Fixed bug that if DetectBackground was enabled, the CPU was hogging after some time
# Fixed bug that BattClock.log.txt was no longer made when debug was enabled
# Added Font selection for installed fonts (Fontname, Bold/Regular)
# Added possibility to specify a gradient color as background color (select top left and right bottom background color, vertical gradient)
# Color picker now makes a screen capture of the upper part, so you can better select the matching taskbar colors (e.g. for gradient colors)
# Added customized OpenFileDialog, so Background images can be selected in all directories, including Windows
# Changed problem that right to left languages like Hebrew text is no longer occupied by +/- buttons
# Updated Hebrew translations, thanks to Som30ne
# Added Greek translations, thanks to padvou
# Changed default colors for low, medium, high into red, yellow, green
4 stripes
Added 4 BattClock stripes, per BattClock stripe the following can be configured:
# Stripe can indicate Battery%, Free Memory%, CPU% or Registry Key 1 (default Phone signal strength)
# the length of the stripe indicates the percentage left
# Background color
# 3 configurable stripe colors dependent on the thresholds.
# 3 different thresholds (low, medium, high)
# X, Y, Width and Height can be configured
# Per 10% a few pixels are not drawn, so you have a good feeling of the percentage left.
# Option to draw a solid line
Added experimental possibility:
# To subclass other windows than taskbar window, so you can put the BattClock items e.g. on your home screen instead of the taskbar.
# Note that the Window Name DesktopExplorerWindow is on my Touch Diamond the Home screen (works in Windows Mobile standard Today screen and Touch Flo 3D)
[B][U]Changes of v2.41[/U][/B]
- added support to use Facebook pic of Manila as CallerID pic.
- added alignment option for Clock/Date (S2U2 Settings > Information).
- added option to exclude ActiveSync email as unread email (S2U2 Settings > Information).
- fixed the reminder would still vibrate if the device had switched to silent mode.
- fixed the reminder period would not work if sleep S2P had activated.
- fixed Appointment's note could not be shown in the pop-up when it's too long.
- fixed occasionally dialing a call was not locked even "Lock on Talk" was turned on.
- fine tuned some misbehaviour when "Proximity Sensor" was used.
- fixed some duplicated translation tags.
- a few minor bugs fixed.
[B]9-5-2010 Version 2.1.1 *NEW* 6 stripes[/B]
# Fixed bug that a freeze of the Start button was possible when a wrong Window Name was set
# Added option to specify the Max value for a stripe, so the value shown does not need to be a percentage
# Added 2 extra stripe possibilities, for RegKey 2 and RegKey 3 (so now 6 stripes possible)
# Updated Russian translations, thanks to Vadim Bogaiskov
Note that people wanting to have a stripe for Battery Current, Battery Temperature or Battery Voltage, they can configure to log those values (see BattConfig Log) and configure RegKey1, RegKey2 and/or Regkey3 to point to the Log:
# HKEY_CURRENT_USER\Software\ZuinigeRijder\Status\Ba tteryTemp
# HKEY_CURRENT_USER\Software\ZuinigeRijder\Status\Ba tteryCurrent
# HKEY_CURRENT_USER\Software\ZuinigeRijder\Status\Ba tteryVoltage
[#] Fixed soft keys: left soft key = "add contact", right soft key = "backspace"
[-] Removed experimental support for dialing via Phone.com
[#] First public release of source code on google code
Version 2 change log:
+ Ideal settings for better listening experience thanks to donalgodon.
+ Internal stereo stays on after restart.
+ Added shortcut to Programs, although it has no icon image but it can be changed with [U][B][URL="http://forum.xda-developers.com/showthread.php?t=567080"]JWMDIconChanger [/URL]v2.7c[/B][/U].
